  • Guests: 39
8Bit binary to 12Bit BCD
Madgyver
Sat Mar 11 2006, 03:55PM Print
Hi,
I want to display a 8Bit binary number as 3digit decimal number with 3 LED displays. The main problem I encounter now, is that most decoders only accept 0-9 bcd or hexadecimal input.
That means for example, that a decimal "20" in binary will be 0001 0100 whcih I cant feed into de decoder.
Is there a easy way to solve this?
Sat Mar 11 2006, 04:38PM
The old-fashioned way to do that is with a PROM containing a lookup table. The table has 256 entries that say which number to display on each of the three displays. Since it takes 4 bits to specify what each display shows, you need a PROM with 256 12-bit locations, and three decoder chips. If you put on your propeller hat for a minute, you can probably imagine how to multiplex a single decoder chip amongst three displays, and at the same time do away with the need for a 12-bit-wide memory.
The easiest way to do it nowadays is with a PIC or similar cheap microcontroller chip programmed with a binary-to-BCD conversion routine. You don't need to write the routine yourself: the manufacturer of the chip should provide a library (although it is a good exercise to try doing it yourself)
Bjørn
Sat Mar 11 2006, 04:58PM
You can also use 3 decade counters connected in series to two 4 bit binary counters. Counting to 255 does not take any significant time.
Personally I would have used the PIC method. Depending on the rest of your circuit you may get away with just a single $3 chip.
Madgyver
Sat Mar 11 2006, 05:11PM
Well I would prefer an AVR anyway, but I want to do it without a µC. The reason is: Its, just for fun.
Thanks so far for the 2 Methods, you two cheesey
