  • Guests: 43
01/13 si2030 (62)
ready made hv power supply
killa_454
Sat Mar 11 2006, 10:29AM Print
killa_454 Banned.
Registered Member #302 Joined: Fri Mar 10 2006, 05:22AM
in old monitors / tv's the curcuits that the flybacks use stock make prety good arcs.
i was thinking that you whould pop the monitor/tv open carefully remove the screen
and put the cucuit board in an enclosure and your done i'll try this soon and post the results
Wilson
Sat Mar 11 2006, 12:19PM
Wilson Registered Member #78 Joined: Thu Feb 09 2006, 11:27AM
Make sure you remove the deflection coils and such as well, or it may act in an unexpected way.
btw, just out of interest, why would one want a HV supply on such a massive PCB when you could make a simple ZVS with 10 components to produce many times the power>
GODSFUSION
Sat Mar 11 2006, 01:08PM
GODSFUSION Registered Member #157 Joined: Sun Feb 12 2006, 08:00PM
Thats what i did when I first learned of flybacks, least its a good way to start.
- Wayne -
killa_454
Sun Mar 12 2006, 02:07AM
killa_454 Banned.
because i dont want to spend any money and im prety lazy right now.
After i get bored of it i'll move on to a better driver.
Self Defenestrate
Sun Mar 12 2006, 02:36AM
Self Defenestrate Registered Member #87 Joined: Thu Feb 09 2006, 01:36PM
If you take some time to reverse engineer the board, you can cut out just the high voltage section. I've done it in the past to create some make-shift supplys, runs the massive hene's pretty well.
Omicron
Sun Mar 12 2006, 09:22PM
Omicron Registered Member #131 Joined: Fri Feb 10 2006, 09:25PM
I might just try that. Any one Know how much power Is produced?
Sun Mar 12 2006, 09:26PM
some times it will be on the back of the monitor, but expect somethign arround 30kv at 1ma
Sun Mar 12 2006, 09:31PM
killa_454 wrote ...
Remember, the curcuit is designed to output continuous voltage that doesn't drop much under normal use, so if you use it for drawing arcs, it won't live too long. The transistor will probably pop in first few minutes of arc drawing fun dead
Omicron
Sun Mar 12 2006, 09:32PM
... wrote ...
Could I use that for my X- ray tube! If so, I am almost done! cheesey suprised cheesey
Sun Mar 12 2006, 10:05PM
its worth a try...
