  • Guests: 32
OiD (38)
jolty (50)
Baran (29)
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Motor Troubles
Billybobjoe
Fri Jan 18 2008, 09:10PM Print
I disassembled my microwave today (to actually fix it - yes, it was difficult not to remove the MOT/cap./diode) to solve an issue caused by a faulty "damper assembly" Link2 and I found that a small 6 RPM motor that connects to a cam that controls the said damper doesn't appear to work. The case reads " 120V 50/60 HZ, 6 RPM, along with some part #s etc.), but it doesn't respond to the appropriate voltage. So I tore it open:
DSC03222
The base is on the left, leading to the cover on the right. The white ring is a single magnet wire coil, and the black piece is a permanent magnet that rotates and is removable from the base.
The whole thing seems very simple but doesn't work. I can get a new one but my microwave is sitting disassembled all over my kitchen floor and if it can be fixed today that would be grand. I'm thinking the permanent magnet may be faulty, but I'm not sure what type of motor this is considered so searching is proving difficult.
EDIT - Also, the resistance of the single winding is approximately 3840 ohms.
Hazmatt_(The Underdog)
Fri Jan 18 2008, 10:32PM
It's a Synchronous motor.
