  • Guests: 35
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Home made x-ray machine.
1 2 3 4
plazmatron
Fri Jan 18 2008, 01:21AM Print
After some very positive comments by the user Mates, I`m starting up this little thread, with one or two radiographs taken with my home made x-ray machine`s.
I first built one back when I was 17 using a radio valve connected to a Tesla coil, but have now moved on to `real` x-ray tubes, and am now using flash radiography at energies exceeding 200keV
1200618058 1134 FT0 Shellpolaroid2
Radiograph of shells taken on `instant` Polaroid film at 50keV and 1 min exposure.
Plug
Radiograph of a spark plug and feeler gauge taken at 80keV, 1 min exposure with variable contrast paper loaded into a Kodak Lanex fine cassette.
Pos
1 minute exposure of V3i mobile phone at 50 keV using variable contrast paper, in kodak Lanex fine cassette.
I currently use only three tubes in my setup. One dual filament medical tube, sunk in oil, which is run upto a maximum of 90keV.
A vintage Matchlett tube, with a thin glass window, which is run in air at 10-20keV (for radiographing plants (below))
1200618868 1134 FT0 Foxglove3
X-ray of a foxglove taken at 10keV on raw (no cassette) variable contrast paper 25 minutes exposure.
And last but not least, a flash-xray tube (pictured below) for radiographing with energies exceeding 200keV.
I will be happy to answer any questions!
Leslie
Fri Jan 18 2008, 02:15AM
I think they are very nice. You are protecting yourself, and keeping a safe distance when generating the xrays?
plazmatron
Fri Jan 18 2008, 02:22AM
Thanks! All the tubes are adequately shielded, and housed in their own room with a remote control. I run a personal dosimetry program too, to be on the safe side. Like anything else on these forums, its safe for as long as you choose to respect it! smile
Leslie
ConKbot of Doom
Fri Jan 18 2008, 05:06AM
very interesting, especially seeing the feeler gage and the different leaves on that.
Mates
Fri Jan 18 2008, 07:03AM
Hi Leslie,
I had the feeling that your work deserves its own thread…
My questions:
Could you somehow specify the total energy (dose) you need for taking some of the pictures? The energy of photons you are mentioning only defines the penetrability of the X-rays. The total dose is usually measured in Gy. In case you can’t measure it directly (the meters with radiation chamber are rather expensive) it would be helpful to know not only the voltage but also the amps. Or alternatively what is the total power sucked by your machine form the wall plug.
What the contrast paper means? Can I use for making similar pictures standard X-ray film and the irradiated object only place on it? Are there any hidden problems with this setup?
Are you using any filters (Al or Cu) for removing the low energy photons?
And finally – maybe some people who have not the possibility of having such third X-ray eye at home would like to know the guts of some other things. I have one which I’d like to order for your next photographic series. I was always very curious where the HV diode in the modern fly-backs is localized (I tried to remove it twice and after hours of crazy work with hammer and chisel I had to give it up without finding it).
Thanks…
ragnar
Fri Jan 18 2008, 11:43AM
[snip]
Why would Leslie want to go out of his way to trivialize his hard work, his costs and his research and his experiments, to put himself out of business? Guys, try it yourself, if you want to appreciate how it's done. tongue
Mates wrote ...
Send him an offer, man; put your flyback in the post! tongue
Mates
Fri Jan 18 2008, 12:54PM
I have the feeling that for Leslie the X-ray photography is a hobby. The nice thing about hobbies is that usually you share the knowledge with other people regardless the costs. At least I’m this kind of person…
Chris Russell
Fri Jan 18 2008, 02:41PM
Chris Russell ... not Russel!
Leslie does have an excellent site with all sorts of information that you may wish to peruse before asking any questions.
My two cents: very nice work, and excellent pictures. Evokes memories of Steven Busic's experiments from some time back.
c4r0
Fri Jan 18 2008, 04:52PM
c4r0 Registered Member #151 Joined: Sun Feb 12 2006, 02:53PM
Hi!
Great photos! I have a few questions too :) By for example 80keV you mean maximum energy of photons, so you are powering x-ray tube from 80kV, right? Or is it average photon energy? You said that you have a dual filament tube. Does different filaments give visible difference in radiograms sharpness? I have double filament tube too, 1mm and 2mm focal spot, and i'm using the bigger one. My radiograms looks a bit blury, is it worth to take apart my oil filled tube casing and switch the filament to smaller focal spot for better radiograms?
Mates wrote ...
Here you'll find the answer: Link2
And here some of my radiograms :)
Intensifying screens comparison: Dr.goos LGY 200 (blue) and Fuji UM Mammo fine (green):
1200674609 151 FT37572 222
Mobile phones: N6310, N6610 and N5110 on photographic b/w paper:
1200674609 151 FT37572 333x
Part of TV remote on x-ray film, lcd display as backlight (you can see pixels :) ):
1200674758 151 FT37572 111
plazmatron
Fri Jan 18 2008, 05:50PM
Hi everyone! Relax its all good, I have no secrets!
Ok where to start!
I dont use filters, since I`m not radiographing anything thats alive, (normaly done to reduce patient dosage since 10-40keV easily absorbed by tissue, and hardly makes it to the film) and every photon counts! (+plus it vastly improves contrast!) Besides the inherent filtration of glass, plastic and oil removes a large portion of everything below 30keV.
The beam currents used for the above x-rays are between 200 and 800 micro-amps, which puts dissipation at the anode at not more than 100W.
I generally run the tubes at as low current as I can get away with, since the exposure time of paper compared with film is quite large, and heat dissipation is by convection (ie not active).
Beam current varies inversely with supply voltage on my setup, as the increased load at high current drains the WC multiplier (the caps are a little small! ) so exposure times
are adjusted to suit my subjects.
C4r0:
The photon energy quoted is the supply voltage, so the vast majority of x-ray photons would probably be around 50-60keV with the most energetic at 80keV.
The dual filament tube I use had one of those integral switches in the base, so I removed it, and have 3 leads to the cathode, h1, h2, and common. It is well worth using the fine filament, though you will have to adjust your beam currents and/exposure times.
You have made some excellent radiographs, I spent many an hour in old.4hv and older.4hv reading your posts!
Leslie
