  • Guests: 39
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
Resonant voltage rise?
Thu Jan 17 2008, 06:03PM Print
Lets say I have a series LC circuit with resistance R in series with it. Is there a formula to calculate the resonant voltage rise of this circuit when excited at a given frequency?
Marko
Thu Jan 17 2008, 07:55PM
Voltage rise in a series RLC will be UR*Q, and Q factor is calculated by
Q=1/R*sqrt(L/C).
Thu Jan 17 2008, 09:11PM
Thanks, but this is just at the resonant frequency. Is there any formula that will tell me the voltage rise/Q factor at any frequency?
Hazmatt_(The Underdog)
Fri Jan 18 2008, 12:42AM
L = 2pi F XL
C = 1/ (2pi F Xc)
little extrapolation;
so L/C = 2pi F XL * 2pi F Xc = 4 pi^2 F^2 XL Xc
so Q = 1/R * sqrt( 4 pi^2 F^2 Xc XL)
or Q = 2piF/R *sqrt(Xc XL)
woops, heh, corrected, and I left the pi alone so you can see it better. I was trying to show that I pulled the 2piF out of the root. Didn't mean to make the equation wrong.
Fri Jan 18 2008, 10:30AM
Yes, just substitute the values of Q and f0 you calculated into the transfer function of a second-order bandpass system, replace all the s (Laplace operator) for j*omega, square the whole mess, and you have the response as a function of frequency.
I found a Google Book that shows the method:
though it solves for the voltage across the resistor, which is probably not what you want.
Hazmatt's calculation looks wrong. :/
