  • Guests: 58
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
A part of me just died...
skmetal7
Fri Feb 10 2006, 11:39PM Print
skmetal7 Registered Member #101 Joined: Thu Feb 09 2006, 08:12PM
dont you just hate it when your meter/ oscilloscope craps out on you and you cant do ANYTHING. well that just happened to me, see for yourself:
i was testing a transformer, thinking that it put out about 30-40 volts, plugged it in and PZZZZT!! multimeter = fried. so would it be worth it to have it fixed (about 5 years-old) or just buy a new one? uggg this sux sooo much mad sad
1139614756 101 FT0 Noooo
1139614756 101 FT0 Noooo2
Alfons
Fri Feb 10 2006, 11:58PM
Alfons Registered Member #134 Joined: Fri Feb 10 2006, 10:44PM
Hmmz looks quite nasty neutral
How much did the meter cost?
If it's cheap enough, I'd say: check if the fried components are easily replaceable / cheap and check if not only some PCB trace is damaged or something. If you can't fix it after trying half an hour or less, I'd suggest you to buy a new one tongue
Sat Feb 11 2006, 06:14AM
unless it was a very expensive meter, just throw it away, or scavenge the parts.
You can never tell by looking at it the extent of the damage, you may have blown some proprietary pic in there, and by the looks of things you blew a few traces...
just let it go cry
Mike
Sat Feb 11 2006, 07:23AM
Yah, if this had lots of very useful features, I'd keep it, but if it's one of those 10$ a pop meters, toss it, it isn't worth it for a mess like that on the board.
skmetal7
Sat Feb 11 2006, 08:34AM
im sure it was a fairly expensive one. it has auto ranging, freq, cap tester, continuity/diode tester, 20 amp current meter, bar graph, temp. all the bells and whistles. the contacts right under the selector are coming off the board. even if i could find the components, i doubt i could solder that precise.
1139646818 101 FT374 Nooo4
1139646818 101 FT374 Nooo5
Sat Feb 11 2006, 01:20PM
Have you determined what the cause was yet??? Seems strange it would blow up from just reading 30-40v from a transformer?? Did you have it on the wrong setting?
skmetal7
Sat Feb 11 2006, 08:10PM
i thought it put out 30-40 volts, but when i plugged it in it arched inside the meter and blew the fuse in my power strip. so either i plugged in the wrong side, or it was some high voltage transformer (looks like a normal trans.)
Eric
Sat Feb 11 2006, 08:29PM
Eric Registered Member #69 Joined: Thu Feb 09 2006, 07:42AM
Or you had it on the current setting? One solution is to get a couple of meters, one 'nice' one and a couple 'popcorn' meters that you won't feel bad when they blow for general use. HarborFreight.com is selling some of the latter for 2.99(!).
skmetal7
Sat Feb 11 2006, 09:16PM
^ good idea.
i guess i should have put it on my variac and slowly turned up the volts.
i didn't have it on the current setting since the meter beeps if you have the probes in the wrong plug on the meter, and your testing volts.
TheMerovingian
Sat Feb 11 2006, 10:28PM
It is impossible to blow a meter with a voltage setting (unless you put more than 1000VDC or 700VAC). Also the range is automatic so no wrong range setting. Probably you have used the Volt reading holes with a capacitance , or continuity or resistance test (they often are on V+ and COM) and this caused the death of the meter electronics.
