  • Guests: 29
OiD (38)
jolty (50)
Baran (29)
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
RF modules
Sat Jan 12 2008, 03:01PM Print
I bought a pair of RF modules from ebay, these to be exact:
]1200149921_95_FT0_tm1000-1.pdf[/file]
]1200149921_95_FT0_rm1sg.pdf[/file]
It says in their datasheets to connect a 50ohm, 1/4 wavelength antenna to them. The length of the antenna is easy to calculate, but how can I calculate the impedance of the antenna? Are the specs of the antenna even critical for short range use? The transmitter boasts 1km of transmitting range, say I only need 100 ~ 200 meters.
Sat Jan 12 2008, 03:39PM
Just do a search on antenna design in GOOGLE. There are MANY calculators, webpages, devoted to this subject.
Sat Jan 12 2008, 03:55PM
A quarter wave monopole above a groundplane naturally has an impedance around 50 to 70 ohms. So if you make a piece of wire a quarter wavelength long and stick it into the antenna socket, the transmitter will see an impedance somewhere around 50 ohms and it should work.
If you want the antenna some distance away, use 50 ohm coaxial cable to hook it up.
Bjørn
Sat Jan 12 2008, 05:18PM
Some times there can be problems at close range so if you have problems when testing them they still might work fine at long range. Antennas can be a very tricky subject at close range, so can cheap receivers.
Mon Jan 14 2008, 08:01PM
Thanks for the tips.
The receiver generates a lot of noise with no signal, and being AC coupled I can't send a continuous signal to keep the output steady. My earlier IR decoder has proven absolutely hopeless as it measures pulse length once per pulse. It doesn't take much noise to ruin the signal then. What would be the best way to transfer data over a noisy link? Should I attempt Manchester coding or is there a better way? Or can I filter out the noise somehow?
