  • Guests: 30
OiD (38)
jolty (50)
Baran (29)
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
wormholes, causality.
Marko
Fri Jan 11 2008, 01:25AM Print
There is a simple thought experiment that always bothered me - how much sense does it make to discuss 'passable wormholes', as they are usually imagined?
If an object is sent through a wormhole, and a laser beam at same time near the wormhole, the object arrives at destination before the beam.
What I can't understand is, why wouldn't this object, even if not locally surpassing c, travel into past for an external observer?
I'm trying to understand the ''spirit'' of relativity of simultaneity here.
I can't easily imagine how could a causality paradox arise here, since it's hard to use logic on this things.
I know there are paradoxes involving accelerated wormholes but I'd like to solve this first. :p
Marko
Bjørn
Sat Jan 12 2008, 03:48PM
With stationary wormholes of this kind you only get "optical illusion" time travel. If you have two clocks and wormhole them around and then compare them side by they will still show the same time even if they appeared to show different times a moment ago.
If you take one wormhole and zip it around at realtivistic speeds (alternatively dangle it above a black hole) for some time it will age slower than the other wormhole and they will get out of sync timewise. Then you can pass a clock between them and make the clocks out of sync.
I would not call this theory but weak hypothesis. We are talking about oversimplified and incomplete equations that give certain solutions of very questionable validity.
Marko
Sun Jan 13 2008, 03:10PM
So there's nothing really preventing me from appearing at destination sooner than light beam sent off near the wormhole at same time...?
Yes, but how does this break causality?
If one throat is time dilated, I still can't see why would object exit before entering.
This got my attention too: Link2
Bjørn
Sun Jan 13 2008, 04:30PM
There are several theoretical ways according to general relativity to arrive at a destination before a light beam taking a straight line. There is nothing in the math that forbids it, but the implications makes everything quite messy and the math gives the impression of being incomplete.
If we go to the extreme and move one wormhole around at the speed of light then it will not age and you can always travel back to the creation of the wormholes by passing from one to the other. I can't see how you can get back to the future you came from again because how would the wormhole know what time you came from? If lots of people jump in at different times and appear at the same time in the past, then back would be a different time for each person.
The more you think about it the sillier it gets.
