  • Guests: 27
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
Best iterrupter scheme
Linas
Wed Jan 09 2008, 05:22AM Print
Hi
i am maked half-bridge sstc wich making 35-30cm sparks (no cap, full-wave), so i decided to make it with interrrupter, because power is 1,5KW, and i believe it produce bigger sparks,
I found a lot of interupter schemes with 555, dual 555 , Pll, ad others, wich is best ??
maybe that one? Link2
confused
EDY19
Wed Jan 09 2008, 05:31AM
I was very happy with my single 555 timer interrupter with only adjustable on and off times. For normal SSTC work (non DRSSTC) I think the most you would ever need is a dual 555 timer design as to include a burst mode (a couple of pulses from the first 555 timer).
Shaun
Wed Jan 09 2008, 05:50AM
I like the one from EVR you posted; I have used this on both my SSTCs, but leaving out everything except PW, PRF, and in one case Single Shot.
The dual 555 Pulse Width and PRF adjustment is very convenient and made controlling it easier to understand and explain to people.
ShawnLG
Wed Jan 09 2008, 07:02AM
I dont think there is "the best" interupter around. There are some that are better than others. It really depends on what you want the coil to do. If you are making a small SSTC, a 555 or hex inverter oscillator will do. For the big coils, you would want something more elaborate, such as the interupter will only interupt on the rising or falling edge of the transition of the next inverter step.
Linas
Wed Jan 09 2008, 09:44AM
EDY19 wrote ...
what spark size and imput power, maybe video can show ?
