  • Guests: 46
09/13 WarrenR (64)
09/13 currentkills91 (32)
09/14 Proud Mary (62)
MicroBoxer SSTC
KresoLiubov
Thu Jan 03 2008, 04:50PM Print
KresoLiubov Registered Member #1153 Joined: Mon Dec 03 2007, 07:27PM
So i decided for upcoming long weekend to make a micro-mini high power SSTC.
Here is a quick shot of components, i need to wash fan in alcohol and lube it. Whole circuit will be housed in plexy case. I need to buy a PCB tomorrow and can start to work. The fullbridge will be from 800 V fets powered by voltage doubler from 220 VAC. Im maybe planing to include small 12 - 600 VDC SMPS if there will stay enougy place on PCB. So whole thing could run from 12 V.
I plan to push insane ammount of power in this coil and keep size as small possible.
Gone to calculate secondary, i plan to exceed its winding length by sparks 2 X rolleyes
The coil is named MicroBoxer by name of fan that pushes insane ammounts of airflow. I wonder will FET-s survive on such heatsinks?
Update soon
1199379052 1153 FT0 Dsc01444
Tom540
Thu Jan 03 2008, 10:23PM
Tom540 Banned on 3/17/2009.
Whats your plan for the SMPS?
Fri Jan 04 2008, 04:17AM
I doubt those heatsinks will let you run at and reasonable power. Even at a 95% efficiency you wouldn't be able to run more than a few hundred watts of input power... I suppose that you could use an interrupter with a 1%i duty cycle or something....
KresoLiubov
Fri Jan 04 2008, 06:28AM
Tom540 wrote ...
My plan is TL494 driving a halfbridge to a ferrite transformer.
Regarding heatsinks i decided to change them and install something more bigger. The coil will be interupted affcourse.
KresoLiubov
Fri Jan 04 2008, 10:39AM
Just little update.
Runned from work to buy all other parts. Quickly finishing work and driver will be finished today. amazed
Logan Kennedy
Sat Jan 12 2008, 05:17AM
Logan Kennedy Registered Member #1103 Joined: Mon Nov 05 2007, 06:02PM
Keep us updated. I'm interesting in seeing how this project turns out.
