  • Guests: 37
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Strange mains waveform/"rattling" noise
Thu Jan 03 2008, 04:30PM Print
This has been puzzling me for years. If I listen at anything that's connected to mains here and it emits buzz (such as a transformer), there's a weird rattling noise added to the hum at a pattern. It usually goes for 1sec. then goes away for 2secs. There are several second breaks where the weird sound goes away.
I'm attaching a sample of the sound that I've recorded near a running transformer.
Anyone dare to guess what it is? suprised
(ignore the "chirping" sound it's a recording error)
]1199377664_152_FT0_strangemainshum.mp3[/file]
Capper
Thu Jan 03 2008, 06:04PM
Capper Registered Member #914 Joined: Fri Jul 20 2007, 06:22PM
Hook an oscilloscope up to it (using series resistors or an isolation transformer) and take a look. It may be a broadcast digital control/timing signal of some kind.
Thu Jan 03 2008, 06:55PM
Thats the core vibrating.
Thu Jan 03 2008, 07:41PM
EastVoltResearch wrote ...
Really? It will go 1 sec on 2 sec off then go away for several seconds, the pattern repeats. Sometimes it gets a bit irregular but not too much. I believe I heard other things than transformers to emit the same pattern but I don't want to make false claims.
I'll try to scope it and see if I can see anything :p
Chris Russell
Thu Jan 03 2008, 07:55PM
Chris Russell ... not Russel!
It's difficult to say what exactly is going on, because the mp3 compression damages the waveform, but at first glance, it appears to be very regular, which is quite interesting. It looks like modulation of the mains, but it's hard to say if that is an artifact of the mp3. One thing that would be helpful would be to get a longer .wav file of the sound the transformer is making, as clear as possible.
Really really helpful would be to construct an isolation transformer, an attenuator, and put the results directly into your soundcard, then get a .wav file of that. That would obviously require extreme caution, however.
At any rate, here is what I got by running it through a narrow filter -- quite obviously a pulsed signal, suggestive of a timing signal of some sort.
]1199390100_1_FT36858_strangehumprocessed.mp3[/ file]
Thu Jan 03 2008, 09:41PM
Here is a link to lossless FLAC file (7 minutes, 7.6MB): Link2
It was recorded using a 230/14V transformer, a resistor divider and line-in to a sound card.
Experimentonomen
Fri Jan 04 2008, 01:27PM
A friend of mine in cz have identified the buzz, its HDO, 216.6Hz for turning water boiling on and off.
ragnar
Fri Jan 04 2008, 01:56PM
HFsstc-freak wrote ...
As in off-peak hot-water-system triggering... ew, but neat.
Fri Jan 04 2008, 02:13PM
Hmm, but why it has such complex pattern then? If you listen to the 7min file I posted, you'll notice there's an over minute long pattern which seems to repeat and is a bit different every time.
Experimentonomen
Fri Jan 04 2008, 02:26PM
I filtered your file, here it is: Link2 <-- 216.6Hz bursts randomly placed.
Hear you can decodethe message heard: Link2
