  • Guests: 29
OiD (38)
jolty (50)
Baran (29)
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Oscilloscope Trouble
Andrew H
Thu Jan 03 2008, 04:31AM Print
Andrew H Registered Member #1198 Joined: Sat Dec 29 2007, 05:39AM
I am having some problems with my o-scope and I don't know enough about troubleshooting them to fix the problem. When I turn it on I get a nice clean trace at 0V. However whenever I touch the probe to something conductive I get this gibberish wave:
1199333964 1198 FT1630 Probe Connected No Input Resize
I also get something similar when I connect the probe to the output of a NE555 running in astable mode when I should be seeing a square wave. What confuses me is the internal self test comes through just fine:
1199333964 1198 FT1630 Self Calibration Resize
It doesn't matter if I have the scope set to measure AC or DC, the gibberish wave looks the same. I also see the same thing no matter where I use my scope (at my apartment or my parents house). I tried using a different NE555 and I got the same gibberish on the scope. Last time I played around with my scope (probably 3 years ago; it's been safely stored indoors since) I could see the output of a NE555 clearly.
Can anyone shed some light on what might be happening?
Thu Jan 03 2008, 04:39AM
The problem lies in the grounding. The ground clip in your scope isn't connected to ground anymore.
The wave you pick up is the 60Hz noise emitted by everything connected to mains.
If you connect the ground for the 555 circuit to the case of the scope you could probably continue to use your probe, but really you need to repair/replace the probe.
Andrew H
Thu Jan 03 2008, 04:58AM
I figured what I was seeing was 60Hz noise. I played with the ground clip and got it more firmly attached. Now when I connect it to the output of the NE555 and the grounding clip to the circuit ground I see a solid line at about 7V (I'm powering it with a 9V battery).
I'll try some different component values and see if that changes anything.
