  • Guests: 52
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
Tube Pinouts
EDY19
Mon Dec 31 2007, 01:42AM Print
Quick questions on tube datasheet pinouts- I was looking at the 6KG6A datasheet here: Link2
and noticed that the grids and screens have 2 connections on the pinout (1,8; 3,6; 2,7;) How should these be connected? Do I only need to connect to one of these two pins for each connection? For example- If i wanted to connect to g1, i would use either pin 1 or pin 8, but not both?
Mon Dec 31 2007, 02:16AM
There are three separate grids. You can put three different voltage potentials into this tube. 1 & 8 would be one of them: say, 120v to 1 and grnd to 8. This would be one current path. You will need another voltage source for the other pairs. By varying the different voltages you control the deflection.
EDY19
Mon Dec 31 2007, 03:00AM
The schematic I'm looking at has g3 tied to the cathode and ground, so should pins 2 and 7 be grounded? Here's the link: Link2
Myke
Mon Dec 31 2007, 03:59AM
Yes you should connect them to ground.
Mon Dec 31 2007, 12:11PM
For my 211 tube tester the filament transformer has a center tap and this serves as the ground for the whole system, isolating it from the earth's ground. The plate and grid grounds go to this. However, using the earth ground is acceptable as long as this is the common ground for everything. On pin will get the voltage potential, and the other will be grounded. If you use all three grids then there will be three grounds.
A great resource and forum for tubes is at Link2
Mon Dec 31 2007, 12:31PM
I completely disagree with Iamsmooth. To me that diagram says that the pairs of pins are connected internally, which means you can use either pin or both.
You might want to use both pins in RF amp applications where you want to minimize stray inductance. The 6KG6A was also popular in cheap and nasty ham/CB linear amps, maybe for this reason.
EDY19
Mon Dec 31 2007, 02:30PM
Steve, I think I agree with you- if one of the "end's" of the screen was grounded (say pin 8), if I apply 90V to one side of a grid (say pin 1), the screen is gonna burn up, plain and simple.
Mon Dec 31 2007, 04:12PM
I don't have a pentode to try, but if pins 1 and 8 are both connected to the grid/screen (a short with an ohm meter) then only one is connected to the voltage source; the other end of the voltage source is grounded. Sorry for the confusion on my part.
Bill G
Wed Jan 02 2008, 07:51PM
Bill G Registered Member #508 Joined: Sat Feb 10 2007, 01:57AM
About 6KG6 / EL509 vacuum tube. This is a power pentode , 9 pin magnoval base, anode (plate) is connected to tube cap.
Each of the three grids in this pentode are provided with two connecting pins on the tube base. This is because in the old days, most tube circuits were wired point to point using terminal strips and components were quite large. A tube grid often had many components attached to it and more than one pin made connecting to a grid easier. I remember this from scrapping huge old tube TV's for parts in the early 1970's (I'm old...) This tube was popularly used as the horizontal deflection amplifier in color TV's
of the early 1970's. Your web datasheet does not agree completely with my copy of RCA RC-29 1975 Receiving Tube Manual. If you want a copy of pages 341 and 342 as relating to this pentode, I could scan the pages and email you if you need. PM me if this would help with your design. On this tube, only apply the needed grid voltages, ie for grid 2 you provide 160v by pin 3 connection, do not ground pin 6, which is the other grid 2 connection. This would only short out the grid 2 supply. I can't offer much more help as I am only an old hobbyist, I am not a designer or electronic engineer.
