  • Guests: 23
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
Some thing, could be transformer
dicban
Tue Dec 18 2007, 08:42PM Print
dicban Registered Member #790 Joined: Sun May 20 2007, 12:03PM
Hello people
I found this thing and I dont know what it is so could you help me what that thing is.
Its quite heavy and it has writen on its self: High Voltage
Th 09780 DSC01637 122 783loTh 09787 DSC01638 122 548loTh 09793 DSC01639 122 1140lo
Thx
ps
the resistances are 6.20kohm and 522ohm
Tue Dec 18 2007, 08:46PM
If it's a transformer, with 522 ohms on the primary it's probably a very low power one.
dicban
Tue Dec 18 2007, 08:49PM
Its quite heavy and large so I thing it could be something powerfull butt i dont know what it is so I asked you guys
Jasonr
Wed Dec 26 2007, 06:24PM
Jasonr Registered Member #167 Joined: Mon Feb 13 2006, 06:41PM
It is most likely a florescent lighting ballast. and a burned up on at that.
MOT_man
Thu Dec 27 2007, 07:09AM
Ahhah! I know what it is! Luckily the Chinese characters are readable - it is type of cold cathode light transformer - these are not solid state but actual transformers running high voltage AC - not sure how many volts but try 120V and see what happens...
Electroholic
Thu Dec 27 2007, 07:34AM
How do you know it is a CCFL transformer? the chinese characters only says "Danger High Voltage"
dicban
Thu Dec 27 2007, 06:30PM
could that transformer be uced for balast choke for balasting MOTs?
mikeselectricstuff
Fri Dec 28 2007, 11:04PM
could be an oil burner ignition transformer
Experimentonomen
Fri Dec 28 2007, 11:11PM
Why not a NST ?
