  • Guests: 31
OiD (38)
jolty (50)
Baran (29)
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
antena feedback 74HC14 modulation
Linas
Sun Dec 16 2007, 11:51AM Print
Hello everybody
I making SSTC , and i need tu make sound modulation, but, how to make it ?
confused
Sun Dec 16 2007, 12:13PM
The easiest way is by using a limiter to clip the audio signal and feed this signal to the enable pin of the gate driver ic. It would sound about like this Link2 quite nice for such a simple circuit.
Reaching
Sun Dec 16 2007, 01:33PM
mh, that sounds "horrible" . nevertheless its really simple. but the enable pin of ucc driver ics can provide much more. why not use a 555 to provide fm modulation and then feed this into the enable pin at several hundred khz. the self resonant signal will get interrupted by the high frequency fm modulated signal from the 555.
Linas
Sun Dec 16 2007, 02:33PM
I can't find UCC drivers, so i using Transistors gate driver....
any ideas how to make it without UCCXXXXX ??
Lomy
Mon Dec 24 2007, 07:28AM
Lomy Registered Member #789 Joined: Sun May 20 2007, 09:32AM
perhops with gate-ICs like 4093(also schmitt-trigger) or 4007. i built a single transistor audiomod test coil with a cd4093, a ne555 fm schematic, and 2-transistors as gatedriver. as oszillator i used a cd4046 or u use a feedback schematic
Lomy
Tue Dec 25 2007, 02:18PM
Lomy wrote ...
ops sry 4 double post i did something wrong :P
