  • Guests: 24
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
Question about parallel GDT IC drivers
Mates
Thu Dec 13 2007, 01:41PM Print
Hi guys,
I’m trying to drive more IGBT’s in parallel and to get a nice wave shape seems to be a challenge. Last time my UCC37322(1) exploded after few minutes run despite being mounted on a heat sink. Are there any hidden troubles associated with paralleling these drivers?
Thanks…
Thu Dec 13 2007, 02:09PM
I think you can parallel them without troubles. AFAIK there are TO-220 versions of some gate drivers, which you can screw on a heat sink.
ragnar
Thu Dec 13 2007, 02:10PM
Use an IXDD414 and your problems will go away. Better still, put your IXDD414 on a heatsink.
Thu Dec 13 2007, 02:23PM
Mates wrote ...
Hi guys,
Thanks…
Check your power dissipation. Is this for a pulsed SSTC (such as a DRSSTC?) If so, your duty cycles will be very low (less than 10%). So if you testing it with a signal generator and running at 50% duty cycle, then no wonder their blowing up.
Also, if you are using gate transformers, make sure your transformers aren't saturating.
