  • Guests: 46
OiD (38)
jolty (50)
Baran (29)
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Simple IGBT welder
Tonic
Tue Dec 11 2007, 04:43PM Print
Is it possible to build a cheap, simple inverter welder strong enough to weld 1-3 mm steel or aluminum frames? The schemes for homemade ones are pretty complex and not for my level. Maybe someone know tutorials, worklogs that would suit me?
I can buy used 200-300A IGBT bricks cheaply. I can also buy ferrite cores by reasonable prices. The power stage of welder shouldn't be a PITA for me, but control stage is a my weakness, thus I'm asking you.
Carbon_Rod
Thu Dec 13 2007, 02:57AM
The price would exceed the cost of a gas MIG welder, argon only tank deposit (works for Al or steel), and gas-less aluminum wire.
Rent a unit for learning (buy lots of wire feed tips), or take a local trades course.
Even with the right tools, good aluminum welds take more practice than one would expect.
