  • Guests: 42
Michael Witt (36)
AleSeg (15)
09/16 Michael Witt (36)
09/16 AleSeg (15)
09/17 Jyardana (41)
ZVS Induction Heater -800W
Dr. H.
Sun Dec 09 2007, 11:43AM Print
After seeing CompWiz ZVS induction heater I decided to build one too. I used the widely spread circuit, the only difference is that i used irfp260 instead of irfp250. I am powering it with 40v and it draws 20A. The work coil is made out of 3mm copper wire 7+7 turns. The tank cap is made out of 5 Siemens MKP 220n 1000V caps, the fast diodes are MUR860 and the inductor is made out of 3 computer iron powder cores connected in series (and yes they do heat up aftee minute or so ). It takes about 10-12 seconds for the bolt to shine bright orange (the camera show it like dim red ). I put in a piece of aluminum just to see what happens and it melted afet about a 30-40s confused. Here some pics - the set-up, some heated objects and the power supply. So what do you think guys shades
1197200542 931 FT0 Pic 4538
1197200542 931 FT0 Pic 4539
1197200542 931 FT0 Pic 4543
1197200542 931 FT0 Pic 4551
1197200542 931 FT0 Pic 4547
1197200542 931 FT0 Pic 4549
1197200542 931 FT0 Pic 4555
1197200542 931 FT0 Pic 4559
colin heath
Sun Dec 09 2007, 12:16PM
colin heath Registered Member #123 Joined: Fri Feb 10 2006, 12:58PM
Thats a nice induction heater. What is really impressive is you managed to melt aluminium directly. this proves it isn't just working on hysterysis losses as with iron.
Cheers
Colin
Bauerb2
Sun Dec 09 2007, 04:28PM
Bauerb2 Registered Member #973 Joined: Tue Aug 28 2007, 07:32PM
amazed wow that is one nice setup you've got there. everything looks nice and organized.
i've always been amazed on how well these work, and i've always wanted to build one too. maybe later though for me...
keep up the good work.
-Andrew
Sun Dec 09 2007, 05:01PM
The good old Mazzilli driver can do anything! Looks like you have it working pretty well, huben Panev, and good job melting aluminium.
Dr. H.
Mon Dec 10 2007, 05:17PM
Thenks guys smile. Because of it;s good performance I am thinking of making a SMPS fot it. Uzzors your circuit looks good. I will look around the net for some more info. I have e few E40 ferites so i will try something trough the next weekend.
CompWiz
Wed Dec 12 2007, 08:47PM
CompWiz Registered Member #1038 Joined: Mon Oct 01 2007, 08:02PM
Mine exploded...
Kizmo
Wed Dec 12 2007, 09:06PM
Mine too cheesey
You wouldn't believe how much smoke/fire/bang they put in at mosfet factory. Surprisingly when some of those (or all) come out, they stop working :)
CompWiz
Wed Dec 12 2007, 09:30PM
Wow yours went way worse then mine.
I was running it on 24v
when I heated a big bolt orange hot the fan slowed way down and the cap got kinda hot.
then I put bigger piece of steel in the coil and hit the switch the coil contracted(!) and POP Sssssssst
mine just let out a big purple flame and lots of smoke
it was not even hot before it died!
my basement smells nice now...
J. Aaron Holmes
Thu Dec 13 2007, 03:13AM
Kizmo wrote ...
Mine too cheesey
It's like... the movie "Alien", but with FETs instead of people. Scaaarrrrrryyyyy suprised
Cheers,
Aaron, N7OE
KresoLiubov
Thu Dec 13 2007, 06:33AM
KresoLiubov Registered Member #1153 Joined: Mon Dec 03 2007, 07:27PM
Kizmo wrote ...
Mine too cheesey
Maybe failure is because i don't see any pads between mosfets and heatsink neutral
