  • Guests: 23
OiD (38)
jolty (50)
Baran (29)
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
GDT Driver with BJTs
nrhoades
Sun Dec 09 2007, 12:25AM Print
nrhoades Registered Member #610 Joined: Wed Mar 28 2007, 09:44PM
I believe I may have found the answer to my question in another recent thread. I took pictures so I'll post anyway.
My question is about the dips in waveforms while using a GDT as a load. The answer may be that I need diodes across the collector and emitter to absorb the magnetizing energy being shot back?
Circuit: GDT Driver module
1197159526 610 FT0 Schematic1
Output with no load:
1197159761 610 FT0 Scheamtic1 Wave2
Output with GDT as load (same as 50u inductor):
1197159714 610 FT0 Scheamtic1 Wave1
Oscilloscope settings: 10V/div, 2us/div
Sun Dec 09 2007, 08:25AM
yes you need the diodes
Marko
Sun Dec 09 2007, 08:49AM
What nobody answered yet is why I need diodes with 50% duty cycle with capacitive load.
Sun Dec 09 2007, 10:38AM
You don't need them with an actual capacitive load.
But don't confuse a capacitive load with a series resonant load running at a leading power factor. While this draws a leading current at the fundamental, it looks inductive to all the harmonics. The current is a phase-shifted sine wave that will want to flow in the diodes at some times.
A real capacitive load looks capacitive at every frequency. The current flows in the form of sharp spikes at the transition times, and the diodes would never conduct.
nrhoades
Mon Dec 10 2007, 06:48PM
You're hi-jacking my thread man! No worries though :)
I added diodes and got the same results. Just some obvious checkpoints:
NPNs: Added 1N5819 with cathode to collector, anode to emitter.
PNPs: Added 1N5819 with cathode to emitter, anode to collector.
Transistors are D-PAK: base = pin 1, collector = pin 2, emitter = pin 3.
I was sure this would work. What am I overlooking?
Mon Dec 10 2007, 10:47PM
I don't KNOW what's cauing the glitches, but here's a couple of things to investigate;
The droop on the 'loaded' waveform looks like the GDT may be saturating
- 'scope the power supply to look for excessive ripple caused by GDT magnetizing current
- try running at two or three times the present frequency (if convenient) to see if the droop decreases
- try short-circuiting the 220 Ohm resistors temporarily
- 'scope the outputs of the TC4428
