  • Guests: 53
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Bad MOSFET-driver signal
Plasmaniac
Wed Mar 08 2006, 02:36PM Print
Plasmaniac Registered Member #206 Joined: Sat Feb 18 2006, 03:17PM
I actually planned make the electronic for my nano tess today. I wasn't sure, if the UCC37321 and UCC37322 MOSFET driver work at frequencies >1MHz, so I connected one to a 1MHz oszillator and this is how the signal looks like:
1141828291 206 FT0 Bad
Where does that spike come from?
Wed Mar 08 2006, 03:09PM
It looks like ringing caused by too much inductance in your ground wiring. Try building everything really small and close together tongue
Wed Mar 08 2006, 03:10PM
Without knowing what your circuit looks like, its impossible to tell where that spike is coming from. Are you looking at just the pin for output, or did you have some type of load there?
Plasmaniac
Wed Mar 08 2006, 03:24PM
I forgot to mention, that the signal above is WITH IRFP250 (shame over my head). The signal without any MOSFET looks like this:
1141830400 206 FT1630 Good
The MOSFET's output (at 300mA, 26V) looks like this:
1141831249 206 FT3520 Mosfet
The MOSFET's signal itself isn't _that_ bad, but the driver's signal looks even worse if I have a loaded MOSFET.
Marko
Wed Mar 08 2006, 05:14PM
Put lots of decoupling caps everyvhere around, gate resistor, and ringing should stop. Also use gate resistor and see if it helps.
You will need to drive it in class E, and maybe make class E preamplifier for mosfet.
For 1Mhz you can get your micro SSTC working with royer circuit as well, if this fails.
Dr. Shark
Thu Mar 09 2006, 09:01AM
In my HF TC experiments I am driving a TC4422 gate driver at 3MHz (thanks Firkragg, without you this would still be running at 1MHz) into a 20n40 or whatever MOSFET. The edges of the squarewave get rounded heavily so it kind of approaches a sine wave, but I do not get any of the crud that you do.
Try keeping all the connections really short; could you post a pic of your setup?
