  • Guests: 20
  • Most ever online: 441
    Guests: 441, Members: 0 on 01 Oct : 16:32
GhostlyFigures (36)
10/05 GhostlyFigures (36)
10/06 Ivan Kalafatic (17)
10/07 Pyromaniac (34)
IGBT oscillators
thrival
Thu Nov 29 2007, 06:31PM Print
thrival Registered Member #1019 Joined: Sat Sept 22 2007, 02:39AM
A few years ago I built a relaxation oscillator using an IGBT (figure A); the damn thing
actually worked although I'm not sure how or why, given that IGBT's are voltage-controlled devices with a capacitive gate, I think the external capacitor could have stayed charged.
I do recall thinking the diode would give the cap a discharge path in parallel with the source, once the gate opened. The waveform was pretty ragged.
Anyway now I'm playing with the idea of a saturable core oscillator using an IGBT and
resistors. I figured that the IGBT's gate should open almost instantly as set by the R
voltage divider, which should then drop out once the coil saturates, and repeat, etc.
Problem I'm running into is I get no action at all. I tried a 2.5" dia toroid with 8 turns of
18 AWG transformer wire as the primary. Thinking maybe I wasn't getting enough XL I tried
a MOT primary, still nothing. The IGBT seems to be good, can't see what I'm doing wrong.
Open to advice anyone might have to offer.
Flyback
