  • Guests: 64
01/12 RoV IW3IPD (63)
Crockroft Walton Multiplier
Clive Hansen
Thu Nov 29 2007, 03:20AM Print
Clive Hansen Registered Member #1149 Joined: Wed Nov 28 2007, 09:30PM
I built a high voltage supply using a very small flyback transformer with an output of 2kv at 20ma. I am unsure of the frequency. I then added a five stage Crockroft Walton Multiplier for an output voltage of 10kv. I noticed that the arc will start at about 1 inch. However, it cannot be stretched as it can straight from the transformer. This limits its use (originally for jacobs ladder). Does anyone know why this is?
-Clive
Shaun
Thu Nov 29 2007, 04:09AM
If you increase the voltage with constant power, the current will decrease. The current tends to affects the "stretchiness" of the arc. More power is what you want (who doesn't?).
What type of flyback and what driver are you using?
Bjørn
Thu Nov 29 2007, 04:28AM
More power makes a hotter wider plasma channel that is a better conductor so you can stretch it further.
Clive Hansen
Thu Nov 29 2007, 05:40AM
I am using this circuit ( which I found online. The flyback was given to me. It is very small and was used to drive some kind of neon tube. The caps are rated 500pf to 30kv each and the diodes are 30kv at 10ma (I think). Could I replace the flyback system with something like a MOT (2kv at 300ma) for increased output current? Or would I have to change the caps and diodes?
-Clive
Thu Nov 29 2007, 04:40PM
You cannot draw an arc out of a CW multiplier because the capacitors discharge (nearly) all their energy as you short it and they have to charge up before next spark. This is normal behavior of any capacitive high voltage power supply.
