  • Guests: 34
OiD (38)
jolty (50)
Baran (29)
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Three phase voltage
Fri Nov 23 2007, 11:36PM Print
If I have a 3 phase generator in a Star configuration putting out V volts per phase will the rectified voltage from all three phases be 1.7*V*1.4?
Sat Nov 24 2007, 06:58AM
It depends on how you wire it.
From what you describe, i want to say its only 1.414*V with good regulation :P.
WaveRider
Sat Nov 24 2007, 01:11PM
Phase to phase Vpeak = sqrt(3) * Vrms..IIRC.
Is your generator V defined phase to phase or phase to neutral?
