  • Guests: 38
OiD (38)
jolty (50)
Baran (29)
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Simple induction heater
nrhoades
Mon Nov 19 2007, 07:30PM Print
nrhoades Registered Member #610 Joined: Wed Mar 28 2007, 09:44PM
Nothing really that impressive... just shows that you can get results easily. Bolt and nuts got up to 450C. Frequency was 200kHz-ish. About 50 to 70 Watts.
1195500613 610 FT0 Indheater A
1195500613 610 FT0 Heatbolt
1195500613 610 FT0 Heatnuts
Tom540
Mon Nov 19 2007, 10:26PM
Tom540 Banned on 3/17/2009.
how long did it take to heat it up?
nrhoades
Mon Nov 19 2007, 11:06PM
Around 30-40 seconds.
I now feel justified with asking questions on this forum because I finally made something that works. Now its time for me to learn!!!:
My heatsinks were too small and the FETs burned out. I knew this would happen and was simply curious. I'm wondering where most of the power (that made them heat up) came from?
Input to rails was 120VRMS (wall voltage), and current in was 0.5ARMS. So power in is about 60W.
RSdon of FETs is 0.5 Ohms... so even if all of the available current went into the load coil, then the power wasted by the fets can't be more then a few watts.
Is this still enough to heat those puny heatsinks into meltdown, or is something else going on (like shoot through)? Any ideas?
PS:
As part of my learning curve, I wasted *ALOT* of time and money because of old capacitors. I recently acquired hundreds of various capacitors from the Navy. I failed to realize that they were thrown out for a reason, not to mention they were decades old. Many attemps to build power circuits failed due to large leakage / mis-markings / super-high ESR of this crap. Transformers, inductors, and resistors can last forever: but capacitors? Get new ones! Now I know.
Shaun
Tue Nov 20 2007, 02:33AM
What is probably contributing to the heating is the IRF740s Rds-ON. 0.5 ohms is a lot. With rectified wall voltage, some lower voltage FETs and a couple TVS diodes might reduce heating.
nrhoades
Tue Nov 20 2007, 03:26AM
I did a Digikey for lower RdsON fets and found an IRFP260 with 0.04 Ohms. I now see the difference between $1 parts and $6 parts.
Shaun
Tue Nov 20 2007, 04:09AM
You can get IRFP260s for less than $6, try Allied Electronics, they are only like $2.80
nrhoades
Tue Nov 20 2007, 05:26AM
Oh wow! I've been throwing away my money with DigiKey... this is now my new favorite distributor.
Tue Nov 20 2007, 11:13AM
Glad to hear you got it to work! Also, what a lovely pink fan smile
