  • Guests: 36
OiD (38)
jolty (50)
Baran (29)
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Sepic vs. ćuk vs. buck-boost; converters
Marko
Sun Nov 18 2007, 05:06PM Print
Hi guys
What are general advantages and disadvantages between these types of converters?
Take an example application: I need to step down and PFC mains voltage (325V) to say 100V.
What converter to use?
All of them need switches rated for Vin+Vout.
Polarity reversal in that case isn't a big problem since my input is AC anyway.
Ćuk and buck-boost invert polarity while SEPIC doesn't.
Ćuk and sepic have low side switch which is easy to drive.
Still, it's not worth putting additional power components just to get low side switch.
Is there actually any benefit from the ćuk converter?
Anything important I haven't taken into account?
Marko
Mon Nov 19 2007, 07:50AM
A straight buck convertor only needs switch voltage rating of Vin + 1 diode.
Polarity isn't inverted (i.e. +100V from + 350 Vdc.)
Marko
Mon Nov 19 2007, 12:57PM
A straight buck converter only needs switch voltage rating of Vin + 1 diode.
Buck can't be used because it can't correct power factor.
So it's a tradeoff for having higher switch voltage; but it's not a special problem if I only need relatively low (<100V output voltages).
thedatastream
Mon Nov 19 2007, 09:05PM
SEPIC converters require a coupling capacitor between the first choke and the second choke/diode that has to carry a lot of current. PP or ceramic is required for this type.
I like SEPICs but that should be qualified by saying I haven't played with buck boost or cuk very much.
Tue Nov 20 2007, 11:22AM
The standard way of doing it seems to be a boost PFC converter that steps up to a 400V DC bus, and then a forward converter that converts 400V to 100V.
I'm not sure why. One reason, I think, is that the PFC will always have poor transient response and a lot of 100Hz ripple, because it's constrained to draw a pure sine wave current from the mains. So they like to put a big bulk capacitor on the 400V bus. You can easily store loads of energy at 400V.
Another reason is that the forward converter can give you an output isolated from the mains.
Yet another reason is that you can buy an off-the-shelf boost PFC controller chip to drive it, I think it's the L4981, or just borrow a complete PFC front end from another SMPS to avoid all the heavy maths wink
Speaking of heavy maths, IIRC the Cuk and SEPIC both have right half-plane zeros, but the forward converter doesn't, so its transient response can be better. This is probably one more reason why they use the two-stage approach.
The boost converter has a RHP zero too, so it might be similar enough that you could hook a L4981 up to a SEPIC or Cuk converter, stick loads of capacitance on the 100V output, and hope for the best! If I was doing this, though, I'd just grab a SMPS from my junk pile and start trying to rewind the transformer for 100V out.
I know Richie Burnett lurks around here, so hopefully he could comment on this... :|
Marko
Tue Nov 20 2007, 03:04PM
I used a rather large lityc there, like 50% of my output filter on low voltages sepic converters. neutral Seeing this Link2 It appears I don't need but a rather small cap over there.... Low-ESR litycs (and tantalums for low voltages) aren't a real problem today... but if I needed really lots of power on mains I could probably go for a non polar cap.
I haven't seen any mains SEPIC applications yet, though.
Steve:
I don't have any special wish yet apart from to learn something, but I liked the idea of being able to power a push-pull royer converter from 230V mains, and use it, for example, to drive and dim fluorescent lamps. Or I might just build a royer and stick a HV transformer onto it, because it's way most efficient circuit to deal with poor power factor loading I know.
The hard switched converter would step down the mains voltage to around 100V and down to zero, allow me to regulate the input to royer and, what would be neat, correct power factor if possible.
Or, in completely other case, I might want to grab a 1200V IGBT and build 0-600V power supply.
Switching from a buck to buck-boost converter costs nothing but some switch voltage which I anyway have, and gives PFC in return.
Still I read about all those other weird types of converters but I don't know much about them.
What is really special about Ćuk, apart from having a low side switch? I don't see how would it make worthy to use over buck-boost in majority of cases.
What's about the claimed lower ripple? (Does that mean lower output ripple Vs. component cost?)
Marko
Marko
Fri Nov 23 2007, 10:52AM
This is where I found about the possibility of using buck-boost as PFC
I would use normal buck boost, not flyback with transformer isolation.
For an example of fluorescent lamp driver/ballast:
But wouldn't this cause lower efficiency (+all the complexity) than a single converter?
And if I was going to do that I would still really prefer not to use a transformer since it's big, lossy and expensive. The only good thing I see from a dual converter arrangement, is that I could change the output voltage at any wanted rate; if I'm powering a royer converter I would need no cap and only a single inductor between it and buck stage, making it effectively a regulated current source.
Then I could even audio-modulate it if I wanted.
But when I look at all that complexity I think that i could actually gain efficiency by removing the royer and transformer fully and using a hard switched halfbridge instead of it.
I have big priority of keeping the complexity of everything down.
But that's getting off the thread topic.
My problem is that I don't understand lots of things Steve is talking about.
I have no clue what planes (RHPZ, LHPZ) are.
What does ''stick loads of capacitance on the 100V output'' mean? Does that mean that I need more energy or the same energy as I would have with 400V cap?
From my understanding any converter that can operate from 0 to peak mains voltage would correct PF equally well.
And my initial question, what's the difference between Ćuk, SEPIC and buck boost?
I understand SEPIC gives positive output voltage, but that's it.
Why is Ćuk used at all over buck-boost when it costs much more (power inductor and cap) and has no obvious advantages?
Can somebody explain the Ćuk converter better? What does this mean: Link2
The advantage of the CUK converter is that the input and output inductors create a smooth current at both sides of the converter while the buck, boost and buck-boost have at least one side with pulsed current.
So does this mean I have 2x less ripple, or what?
PS. To add... I absolutely don't need isolation from mains anywhere here, as I don't want to touch any of these voltages anyway. So I want to avoid any transformers unless they are really needed.
Fri Nov 23 2007, 03:23PM
Here is everything you never wanted to know about variable-output PFCs, courtesy of Richie
stee
Fri Nov 23 2007, 09:41PM
That was a nice read. I must have learned something in school since i could follow all of it.
Marko
Sun Nov 25 2007, 01:44AM
Interesting, I didn't imagine the buck+boost topology as such... but very good and easy read for me...
They didn't cover other converters like buck-boost and Ćuk though - I expected buck-boost to be at least given as a possibility (especially because they are on 115V input voltage) but isn't even mentioned...
One thing I noticed, why are there recovery losses on the input rectifier? Shouldn't the decoupling cap take care of that (at cost of little worse power factor)..?
