  • Guests: 46
OiD (38)
jolty (50)
Baran (29)
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Repairing a 5V 2.5A SMPS?
Sat Nov 17 2007, 07:48AM Print
Hi all.
Plugged in my router supply the other morning and SNAP Crackle POP! :( GRRRR
Took it apart and it seems to have popped the main fuse, due to two of the four input diodes going bad, possibly triggered by the infamous brown glue disease.
Changed the bad diodes, cleaned off glue, replaced fuse. Now SMPS no longer blows fuses and the main capacitor charges but still no output. I'm seeing about 150 ohms on the output which is consistent with output resistor.
Any ideas? this supply was for my vigor 2500 router.
I checked around the drive circuitry and there was a lot of brown glue on the optocoupler, but this seems to test OK.
thanks, -A
"Bother" said Pooh, as his Dell laptop erupted like the Hindenburg..
Sat Nov 17 2007, 08:56AM
Conundrum wrote ...
Hi all.
Forgive my ignorance, but what is "brown glue", and what is the disease associated to it?
Cheers, Finn Hammer
Marko
Sat Nov 17 2007, 12:47PM
Can you post some pics and/or descriptions of parts on the board?
Blowing the fuse indicated primary side failure... now, I just hope you don't have one of those TOPSWITCH© in there ill
Failing to repair it you might just pull out 5V from your PC power supply to power the router.
Or simply use old fashioned iron cored transformer. 12.5 watts isn't that big deal.
Oh, and I'm curious what is ''brown glue disease'' too...
Sat Nov 17 2007, 07:20PM
Brown glue? Is this related to the factory-installed 'blue smoke' on which all electronic devices operate? Everyone knows that when a component releases its blue smoke then it no longer works, and we must get a replacement for its fresh supply of blue smoke.
I used to have a handle on life but it broke off
Sat Nov 17 2007, 10:17PM
The original fault was probably the switching transistor blowing short, which took out the diodes and fuse from overcurrent the first time. The next time you tried powering up, it blew the shorted transistor open.
