  • Guests: 36
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Parallel LCR Q
Marko
Fri Nov 16 2007, 12:09PM Print
It frustrates me to see how much things I just don't think about, and when I start I figure out I have no clue about them.
Q is supposed to be RsqrtC/L (for parallel R), and it should also be the current magnification factor, circulating/Iin. (????)
But, in a EWB simulation, I gain no Q by increasing C and decreasing L proportionally; current is always nearly the same when powered by a current source.
With voltage source, both currents increase proportionally with increase of C/L ratio; but their ratio doesn't change.
Also, it's simply not intuitive to have Q proportional capacitance - isn't energy going to be wasted very fast if we just put a short over a huge capacitor?
What is Q then after all, here?
I may be just setting something wrong out in the simulation, or have some grave misunderstanding. I struggle even with EWB.
nrhoades
Fri Nov 16 2007, 04:55PM
nrhoades Registered Member #610 Joined: Wed Mar 28 2007, 09:44PM
Post a picture of your simulation schematic. Remember to add a Thevenin/Norton source resistance to seperate the nodes.
Heres an example:
1195232112 610 FT34320 Sim1
Marko
Sat Nov 17 2007, 01:08AM
Like this.
1195261709 89 FT34320 Rlc
My problem is that I don't have clue what to expect at all - how should it be in reality?
Note that my resistance is series with inductor, although I don't see what would this specifically change.
Marko
