  • Guests: 32
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
protection of IGBT (FET) ?
Mates
Thu Nov 15 2007, 08:57PM Print
Hi guys,
After my double IGBT death while pulling plasma from the top load of my tesla coil I came with an idea of additional protection of expensive transistors. The point is to connect a strong diode (made form a bridge which is cheap and can stand almost anything) in series with the transistors and put big cap (3.3uF) parallel to this diode. (check the scheme)
I think it could help the transistors in many ways:
First the diode works like non-inductive resistor protecting the short-circuit situations. Next the diode is slower allowing the transistor to be fully open before the energy goes through it. And finally in combination with a big cap it should help to keep the deadly spikes down.
Comments welcome…
1195160173 1025 FT0 Protected
Shaun
Thu Nov 15 2007, 09:17PM
How will the diode act like a resistor?
And why from a bridge rectifier? I know there are single diodes more than capable of this.
Plus, I'm pretty sure a cap in series with the IGBT will not stop spikes; parallel smoothing caps do this.
Mates
Thu Nov 15 2007, 09:51PM
Shaun wrote ...
Diode is not an ideal conductor - I don't know what is the total resistance but it must be significant (hopefully it is more than the open transistor but honestly I don't know)
Shaun wrote ...
Bridge is cheap, easy to work with (usually isolated) and you can get it from every old electronic device (I have tens of them at home). But otherwise you right...
Shaun wrote ...
The point is that the cap should stop the spikes already to protect the diode. No further spikes should appear behind the diode (the diode must be very close to the transistor to make sense). But right, there could be another decoupling caps paralel to the transistors to be double sure...
Shaun
Thu Nov 15 2007, 09:58PM
Okay I understand now. The only thing I think is still worth mentioning is that most diodes have essentially negligible resistance; they mainly dissipate by way of their forward voltage drop. So do IGBTs, which is a big part of why IGBTs and not MOSFETs are used for DRSSTCs.
