  • Guests: 92
Rogowski coil calibration
TheMerovingian
Thu Nov 15 2007, 10:56AM Print
I have built a rogowski coil wound on a coaxial wire. It is connected to an active integrator and to the o-scope via bnc connector. The purpose is to measure coilgun waveforms. The sensibility and the offset are adjusted by two potentiometers. Sensibility can be adjusted from 0.1mV/A to 10mV/A. I want to adjust it in the range of 4 or 5 mV/A. Any advices?
Coilgunvswitch2
Coilgunvswitch
These waveforms belong to a coilgun pistol with SCR-VSWITCH without the projectile inside, the negative di/dt during the decay phase of the capacitor discharge is enough to trigger the second scr (the small peak) and inibite the current. For safety purposes i didn't use the projectile
Thu Nov 15 2007, 01:45PM
According to the second paper, the mutual inductance is just u0 times the cross-sectional area of the coil former times the number of turns.
TheMerovingian
Thu Nov 15 2007, 02:29PM
interesting. I'll try these methods
