  • Guests: 64
01/12 RoV IW3IPD (63)
Cool circuit
Spedy
Wed Nov 14 2007, 04:37AM Print
Spedy Registered Member #964 Joined: Wed Aug 22 2007, 12:39AM
You might have seen this before, but I still think it's pretty cool. It's probably absolutely useless for the HV made here due to its over-sensitivity, It'll light up due to sky voltage INSIDE (I'm pretty sure the house shields the sky's E-field from the inside..) a house, but only if you toss it into the air so it isn;t just part of the "ground" electrode and not picking up the e-field. It'll pick up someone petting a cat from approx 2 meters and when you're holding it and scuff your feet on the carpet. I like it a lot, it's a ton of fun to see how electrostatic the common world really is.
The original web page
My Device: It is the circuit (omitting antenna resistor, earth-ground) hot-glued between a couple of plastic pieces cut from the walls of an old milk carton. It's sealed around the edges, the "on-off" switch is simply the 9v battery clip, one side "snapped" onto the battery so it could spin around it, and on-off is obtained by putting the other side of the clip in or out of contact with the other battery terminal.
1195014991 964 FT0 Pb130001
1195014992 964 FT0 Pb130002
Enjoy.
Avi
Wed Nov 14 2007, 12:53PM
Is that safe to connect an LED in a circuit using a 9v battery with no current limiting resistor?
Spedy
Wed Nov 14 2007, 03:42PM
Well, I read on the page w/ the circuit that the JFET does the current limiting; and my led hasn't died yet :)
Bauerb2
Wed Nov 14 2007, 05:38PM
Bauerb2 Registered Member #973 Joined: Tue Aug 28 2007, 07:32PM
as the field changes around the fet gate the current is limited through it, changing the LED birghtness.
i built it before a few years ago. fun stuff.
-pz-
-Andrew
Shaun
Wed Nov 14 2007, 09:07PM
lol great minds think alike
Spedy
Wed Nov 14 2007, 10:34PM
Heh. You ordered parts for 20 of the things? Lol, w/ prices these days, the batteries for them would probably cost more than the parts. You could build all of them and do a "charged object hunt" like it says farther down the page.
Great minds do think alike :)
Shaun
Thu Nov 15 2007, 04:04AM
I never intended to build 20, its just that at the time 20 probably cost like $2 on digikey, and I figured "What the hell, I'll probably zap a few anyway with various sources of HV I have around here!"
What was neat was hooking a scope up across the LED. If you put the scope on AC mode with a footlong antenna you can pick up all sorts of HF noise, 60Hz mains, etc. But then again you can do that by just attaching a wire to the scope probe...
