  • Guests: 27
OiD (38)
jolty (50)
Baran (29)
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Vertical Axis Turbines
Tue Nov 13 2007, 03:50AM Print
After I build my own 3phase generator I will need to connect it to a mover. Since I have 80' oak trees that I am not cutting down there will be low wind and turbulence. I think if I am going to do anything it will have to be a vertical axis design.
I have seen multiple vertical axis designs on YouTube. Does anyone have any knowledge if one design is better than another for converting wind energy into rotational motion?
Thanks?
bob golding
Thu Nov 15 2007, 10:50PM
bob golding Registered Member #1084 Joined: Mon Oct 29 2007, 08:58PM
hi,
if you have low wind and turbulence you dont want a vertical axis turbine. they are very ineffiecient campared to hawt's. have a loook on Link2 for some ideas. Link2 has some vertical designs as well. ed lenz is proberly the expert in verical axis mills on the home made turbine scene.
good luck
bob golding
