  • Guests: 56
Coil Winding??
Cwazy
Sat Nov 10 2007, 12:12AM Print
Cwazy Registered Member #1106 Joined: Thu Nov 08 2007, 01:15AM
So i am blank once i thought of this question but how do you wind a proper coil?but there are no guides on how to..
i know you start at the projectile loading side then go foward. . then put some super glue on. . then do you wind it back to the start?? then do the same thing over and over??
Simon
Sat Nov 10 2007, 12:36AM
Yes, you wind and wind and wind... back and forth along the coilform.
Set yourself up properly, make yourself comfortable and think about life, the universe and stuff.
Some tips:
Turning the coilform instead of wrapping the wire gives much better results. It's good to put the coilform on some kind of axle to make a lathe. Best of all if you can motorise that lathe (slowly).
Using some glue between layers can also help you tell the difference between the layer you're working on and the layer you just wound. You'll appreciate this once you get a few layers down.
Cwazy
Sat Nov 10 2007, 01:27AM
ahh great thanks!
