  • Guests: 38
OiD (38)
jolty (50)
Baran (29)
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
3 phase generator
Thu Nov 08 2007, 09:00PM Print
The simplest permanent magnet 3phase generator has three coils and one rotating magnetic pole consisting of a N-S pair. My question is very specific: can one have two poles (4 magnets total) with three coils for a three phase generator?
Dr. Slack
Thu Nov 08 2007, 09:24PM
conventionally, a single magnet has a North pole and a South pole, so 2 poles per magnet.
So if you mean "can one have two magnets (4 poles total) with 3 coils", the answer is yes. You will get 2 electrical cycles per revolution of the rotor, rather than one, if they are arranged in the obvious way.
If you mean " can one have two poles (4 magnets total)", then I don't know what you mean.
Chris
Thu Nov 08 2007, 09:30PM
Chris Registered Member #8 Joined: Thu Feb 02 2006, 04:34AM
A typical car alternator is a 3 phase generator with 8 or 12 rotating poles, so definitely. Thus it is easy for them to output well over 1kHz, by the means that NeilThomas explained. A 3 phase generator is just the same as a 3 phase synchronous motor being driven.
Avi
Sat Nov 10 2007, 12:01PM
NNSS (facing outwards)?
