  • Guests: 35
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
True RMS Meters
Billybobjoe
Tue Nov 06 2007, 01:32AM Print
I recently purchased a relatively inexpensive 400 amp AC digital clamp meter and it is not listed as True RMS. I do have another True RMS meter but I needed a clamp meter for high currents and for the convenience of not having to break the loop, etc. I plan to use this meter for common mains voltage readings for motors, heating elements, and also with devices using a homemade inductive ballast.
My question is if the measurements using the non "True RMS" meter will be inaccurate when used with inductive loads? I was under the impression that True RMS is really only used with non-sinusoidal waveforms, and wouldn't be affected with leading/lagging current or voltage, but now I'm not so sure.
Also, if I'm going to return this meter, can anyone recommend a respectable clamp multimeter? And how useful is it to most people to have the ability to measure both high current AC AND DC?
Tue Nov 06 2007, 09:57AM
Yes, no matter what the power factor, the current should still be a sine wave, so it should read fine.
Wolfram
Tue Nov 06 2007, 11:40AM
Things with a rectifier and a smoothing capacitor directly on the mains input (like older SMPSes and the like) draw a non-sinusoidal load current, and will most likely give wrong readings with a non-TRMS-meter.
A.M.
Overclocked
Tue Nov 06 2007, 08:32PM
Overclocked Registered Member #1056 Joined: Thu Oct 11 2007, 11:15PM
True RMS is Nothing more than,
ETRMS= sqrt (EDC^2 + ERMS^2)
Wont make much of a difference unless there is a DC component in your AC component. Some meters have a switch to switch between RMS and TRMS
Billybobjoe
Tue Nov 06 2007, 09:54PM
Alright, thanks guys! Now how useful is a high current DC measurement? Anything with SSTC's? The only thing I can think of would pertain to car batteries or other large battery banks.
Hmmm . . . to take it back or to not take it back . . .
