  • Guests: 50
Digital simulator
ShawnLG
Tue Mar 07 2006, 02:03AM Print
I have stumbled apon this and I thought you guys might find a use for it. Much easier than using a proto board!
Thingmaker3
Tue Mar 07 2006, 05:11AM
Thingmaker3 Registered Member #124 Joined: Fri Feb 10 2006, 01:30PM
I'll stick to breadboarding, thanks. I've never met a freeware simulator that I trust.
ShawnLG
Wed Mar 08 2006, 04:47PM
"I'll stick to breadboarding, thanks. I've never met a freeware simulator that I trust."
Linux is free and some people trust that more than MS winblows. I have tested a circuit with the sim and it works currectly so far. The only thing that is wrong with it is that I cannot save.
Wed Mar 08 2006, 06:26PM
I've never met a commercial simulator I can trust either cheesey That's not a reflection on the quality of the product, it's just the nature of simulation that you can never be 100% sure the circuit you're simulating is the same circuit you are building. The simulator doesn't model all the parasitic components, and it takes a lot of experience to know which parasitics are important in a given situation.
For analogue work, I find LTSpice very good, and ironically it's free.
Michael Witt
Wed Mar 08 2006, 10:20PM
Michael Witt Registered Member #282 Joined: Sat Mar 04 2006, 11:45PM
The sim seems to be a pain in the butt to use. It took me fifteen minutes to get a circuit working that was Vcc -> LED -> Gnd. I think I'll put that in the back of my mind, but it needs lots more faetures before I'll use it (Like diodes, TRUE diodes).
