  • Guests: 45
Tek TDS210 Software
Mon Mar 06 2006, 11:40PM Print
Adam Horden Registered Member #176 Joined: Tue Feb 14 2006, 09:35PM
Hi All,
I have a TEK TDS210 scpe with the comms module and I am after a copy of the software for the unit. The orginal version to go with the moudle was free but Tek no longer have it on there site cry. I spent 3 hours on google and could not find anything.
Does any one have a copy of wavestar they can send me or know to some other free software that allows me to download scope shots from the unit? It will be very hand to be able to do this and it cable be done from hyperterminal but its a bit long to type in the commands etc.
Adam
Carbon_Rod
Tue Mar 07 2006, 12:11AM
Not free man:
WSTRO Software, WaveStar; for Oscilloscopes,for Windows 98/ME/2000/NT 4.0 US $330.00
But code is around:
tdsdump (linux) Link2
Tektronix C Link2
=oP
Tue Mar 07 2006, 12:21AM
If you call tektronix directly, they will send it to you provided you own the original oscilloscope (just need to provide serial number)
Carbon_Rod
Wed Mar 08 2006, 07:21AM
Just a heads-up if anyone is planning to use this software.
The WaveStar 2.8.1 30 day demo software from the OEM site is some of the worst coding I have seen in years.
I was curious about the GBIB interface they use and discovered a few things:
1.) When you install, the tray monitor also probes the LAN looking for attached devices.
2.) Uninstall may leave many of the support drivers on the system.
3.) When you uninstall it may LEAVE YOUR SYSTEM INOPERABLE. Make sure to backup your system DLLs like MSVCRT.DLL on older systems or you will have to reinstall your OS.
Carbon_Rod ***Gives VM a beer, then deletes last session image changes***
Wed Mar 08 2006, 09:37AM
Thanks all,
I should get a copy from the rep.
Wavstar is crap its probing all my lan devices at the moment and found the printer server as a scope mad I wish it was a TDS3000 sersies like it stated it was cry
Tek do have some free software for the scopes called OpenChoice but I have not tired it with a TDS210 yet but it says it should work.
Adam
Wed Mar 08 2006, 10:51AM
Carbon_rod, you've never seen any of my coding wink
Adam, I think I might have a copy of the "old" Wavestar (before they turned it into a bloated mess like carbon_rod found out) on a machine somewhere. I don't have the install disk but IIRC, it works if you just zip up the install directory and copy it to another machine. I'll see if I can find it later this week.
*edit* Found it, what's your e-mail address
Steve
Thu Mar 09 2006, 08:36AM
Hi Steve,
My email address is **link**
Cheers for finding it.
Adam
