  • Guests: 50
09/13 WarrenR (64)
09/13 currentkills91 (32)
09/14 Proud Mary (62)
Home made neon (or rather air) tubes with fridge comp.
Zum Beispiel
Thu Oct 25 2007, 05:16PM Print
(I am posting this under gen. science because it deals with affordable vacuum pumps. If someone thinks it should be at high voltage or somewhere else, feel free to move it)
I did some cleaning around the lab and came accross this refrigerator compressor. I was going to use it as a crappy vacuum pump once, but never got round to it.
I was going to throw it away because it's damaged and makes a real loud sharp noise - one of the internal supports has fallen off. And I don't really need it anyway, as I have access to a proper vacuum pump. Here's the compressor.
1193331459 514 FT1630 Compressor
I saw some clear tubing lying on the floor and then it hit me: Could a fridge compressor be used to pull a good enough vacuum to make some pretty plasma? I immediately put together a test setup. Please note all my super air tight connections :p.
1193331459 514 FT1630 Setup
Also notice the wonderful amprobe ammeter in the foreground. That thing is like 50 years old and still going strong!
So, to answer the question, yes, a fridge compressor can get a good enough vacuum to make some plasma, even in such a horribly sealed system.
Results:
1193331459 514 FT1630 Plasmalight
And in the dark:
1193331459 514 FT1630 Plasmadark
Power in these pictures is really low, only about 50V into the bridge. At higher powers the tube melts almost immediately.
Also, at higher powers, this happens:
Oh
Not good, at all :(
The tube was completely lit and bright but it arced just before the picture was taken :(
So, in conclusion, a fridge compressor, while usually regarded as kind of weak, can give some nice results. Not good for any serious work, but great for some plasma fun.
And the price is right too wink
Ps. I kinda worry about generating X-rays, though. There certainly is enough voltage to do it. The vacuum is so bad that I doubt it can generate any x-rays, but if anyone thinks different, I'd like to know!
Thu Oct 25 2007, 08:41PM
Thats impressive, you may have just spurred me into some fun with a VERY large glass jar I have.
Thu Oct 25 2007, 08:55PM
Nice. Why don't you try evacuating a glass jar?
Zb wrote ...
Besides the vacuum being too low, there would need to be a target for the electrons to collide into. So no, don't worry about it. Even if it could, I doubt the x-rays would be more dangerous than normal background radiation.
Hazmatt_(The Underdog)
Thu Oct 25 2007, 11:25PM
I've heard that 2 fridge compressor pumps in series can make a very effective vacuum pump.
If you do evacuate a glass jar that's not vacuum rated, make sure you take precautions againts implosion, like using wire mesh around the glass jar, staying behind plexiglass, using eye protection, etc.
Fri Oct 26 2007, 12:03AM
The glass i have in mind is 6 gallons and has ~1/8" - 1/4" glass at the thinest. I don't plan on taking it down into a heavy vacuum, just enough to get a good glow discharge from, a flyback or NST (rectified).
likewhat
Fri Oct 26 2007, 12:48AM
likewhat Account deactivated by user request on 6/11/2009.
Registered Member #1071 Joined: Fri Oct 19 2007, 02:13AM
Here is a paschen curve for air
looks like around 200 mtorr is the easiest to break it down.
Wolfram
Fri Oct 26 2007, 09:47AM
I've actually done the same lately, but with a dual stage rotary vane pump and glass tubing. It's quite entertaining. It's not too hard bending the glass into shapes, and I've made a few letters and short words. Right now I'm trying to get Neon, but Spectra Gases somehow don't seem to want to give me a price quote for neon.
I'll post a few pictures when I get back from England.
Dr. Slack
Fri Oct 26 2007, 11:55AM
As far as the strength of the glass is concerned, there is hardly any difference between a vacuum of 0.1 bar (still too soft for plasma fun) and 0bar (total (or heavy) vacuum), like 0.9bar versus 1 bar differential pressure. Even 1/4" sounds mighty thin for surrounding 6 gallons, unless it's been manufactured as a vacuum vessel. If it's been made as a liquid container, then you really need that mesh, and plexiglass shield, and the ABS glasses wouldn't go amiss as well.
Sun Dec 09 2007, 04:14PM
I found myself a fridge compressor and a suitable container that could stand up to the pressure in hopes that I could have some fun. The fridge compressor managed to lower the pressure enough for a 7kv(DC) source to strike an arc across a 1 1/2 inch gap which is far longer then it would be at regular pressure. I also managed to get some really good purple plasma "clouds" between the wires but they don't show in the video. The container is a steel bowl with a 1/4inch sheet of plastic over it.
(Sorry about the quality, the uncompressed version is 166mb and you can see much more detail)
*edit* I forgot to mention the powersupply is never turned off during the video only the compressor. The arc goes out when the pressure gets closer to normal.
Zum Beispiel
Sun Dec 09 2007, 05:04PM
Is the plexy just laid over the bowl with no gasket? suprised
Try making it a bit more airtight... A good fridge comp can get pretty low... Getting to "plasma globe" pressures shouldn't be a problem.
Oh, these are fun things to play with smile
