  • Guests: 31
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Ford Fuel Injectors jam after being saturated with water content
Carbon_Rod
Wed Oct 24 2007, 06:40PM Print
This one has me a little puzzled,
The Ford Fuel Injectors are the magnetic type. They are saturated with high-water content liquid for a few days. The cores work great at first, but then behave as if they are clogged/jammed if left for only a few days.
These are stainless steel, I can only guess it is the seals (corroding), return spring degenerated, or the slug may be magnetized.
Before I take a saw to open this part up, I wondered if anyone encountered this type of issue?
Sun Oct 28 2007, 09:43AM
hehe.. if it was mine i would use an ultrasonic cleaner on the beastie, with deionised water or something like IPA as the solvent.
This won't hurt the cleaner, they are designed for this.
you can get these from CPC, for around £25 UKP
regards -A
Tesladownunder
Sun Oct 28 2007, 03:39PM
Carbon_Rod wrote ...
My mind is trying to comprehend how such a fluid came to be in your fuel. Did you pee in your fuel tank?
TDU
Sun Oct 28 2007, 05:03PM
More likely that water accumulated at the bottom of the tank, as happens on nearly every car if it is left for more than a week.
(both me and my GF LOL'd at the "pee in tank" comment!!)
-A
"Bother" said Pooh, as he received his STD test results..
Carbon_Rod
Mon Oct 29 2007, 04:18AM
Ureic acid is not good for water =P
if such a situation arose methalhydrate would work better.
The valve is not for normal automotive use. It was new, used in clean system, and fed by a clean fuel pump.
Although, perhaps forcing through some sodium hydroxide etc. may clean it. :)
