  • Guests: 33
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Wind Generators
Mon Oct 22 2007, 03:52AM Print
Is anyone familiar with VERTICAL wind generators? They rotate vertically with a helical sail as compared with the standard propeller configuration. Do they work well?
Does anyone know of any residential grid-tie installations?
Coyote Wilde
Mon Oct 22 2007, 04:49AM
Coyote Wilde Registered Member #175 Joined: Tue Feb 14 2006, 09:32PM
They tend to be less efficient, break more often (bearing stresses from greater sail area and whatnot) and most have difficulty self-starting, except for the very least efficient models. Unless your site is very gusty and turbulent so as you need the omnidirectionality of a VAWT, then you're better off with a horizontal-axis turbine.
Don't know of any made/certified for residential grid tie, but I tend to focus on the homebuilts at by lurking at places like fieldlines.com (discussion board for Otherpower.com) -- those folks probably have most of your questions covered in their archives.
Bjørn
Mon Oct 22 2007, 05:17AM
These seems to work very well Link2
stop4stuff
Mon Oct 22 2007, 08:06PM
stop4stuff Registered Member #64 Joined: Thu Feb 09 2006, 06:25AM
loadsa goodness about VAWTs over at Link2 . Have a search for Ed Lenz' Lenz2 turbine... you'll also find enough info to keep you busy for a while re grid tie (& stand alone) systems
