  • Guests: 75
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
transformers gone bad
rp181
Mon Oct 22 2007, 02:08AM Print
Ok, so today i make my first atempt at high voltage, had a step down transformer, un wound it, and re coiled it with primary being 95 coils of 22 gauge ( i think), and secondary was 293 coils of fairly thin wire ( was already in transformer). Hooked up to 12V AC, got a buzzing sound and tiny spark when touched. I then put directly from outlet (110V AC) flipped the switch. The primary coild burst into flame( not very big =( ), and the enamel was burned right off. How do i fix this? use thicker wire for primary? Does secondary have to be thicker then first?
EDIT: "circuit" went like this.... power outlet to 120V AC 2Amp switch, to primary winding. Secondary was connected to 2 electrodes taped close together.
Dr. Slack
Mon Oct 22 2007, 03:53PM
If there aren't enough turns on your primary to handle the input voltage, then thicker wire is not going to help.
You need to have enough primary turns so that the core stays out of saturation when you power it. Measure the iron area of your core, assume a figure like 1.7T (or so) for peak flux, and compute the peak volts per turn that would be generated by the flux swinging in a sine-wave fashion from +1.7T to -1.7T in half a cycle of mains (that's 534 T/s in europe, 641T/s in the US). That needs to be greater than the peak volts that you apply to the winding, otherwise it gets quite hot quite quick.
