  • Guests: 34
OiD (38)
jolty (50)
Baran (29)
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
~75kHz Interference
Simon
Sat Oct 13 2007, 11:13PM Print
As a part of a university prac, I've been using a scintillator to detect muons and measuring the timing of pulses to estimate halflives.
We've got nice data but there's a huge spike in the ~13us time period, which corresponds to ~75kHz. I'm curious as to what this interference could be. It seems too high fres to be a CRT.
Any thoughts?
This is a lab environment with lots of equipment (nuclear sources and the usual electronic lab gear), so I guess it could be anything.
Amateur-Scientist
Sun Oct 14 2007, 03:39AM
Amateur-Scientist Registered Member #1015 Joined: Fri Sept 21 2007, 06:43PM
It could be a nosiy switching power supply.
Sun Oct 14 2007, 05:00AM
I can hear noise from one of my CRT monitors well into the HF spectrum, above 10Mhz. If theres one thats arcing slightly to the core of the flyback, or that has a dodgy capacitor, it could easily generate a signal in that range. It isn't likely to be quite that narrow though. I'd wager its something using a cheap oscillator or a dying appliance nearby.
Dave
Carbon_Rod
Sun Oct 14 2007, 05:38AM
IIRC CRT fly backs are usually only 12-25KHz
Best way to track the problem is to selectively shutdown (unplug) each piece of equipment to see if it changes.
Some noise sources that can be detected in sensor front ends:
Calculators
Wrist watches
Cellphones or iPods
Florescent fixtures (in laptops too)
Broadcast antenna
Old equipment (oscilloscope or spectrum analyzer too.)
Security System (and smoke detectors)
WiFi or network points (often slip by the FCC)
Exhaust Fans
Corrosion monitoring probes
Rule number 1: Never mix analog and digital areas unless absolutely necessary.
Rule number 2: The Sun's EM spectrum is quieter just before dawn.
Not knowing the design, I can only blindly recommend testing the design with batteries (helps for debugging jfet amps or National's weirdness.)
Cheers
Sun Oct 14 2007, 06:51AM
Simon wrote ...
Any thoughts?
Yes, some CRT monitors can have line frequency up to 100khz, and 75 is fairly common for a computer monitor
Simon
Sun Oct 14 2007, 08:32AM
wrote ...
Not when "each piece of equipment" includes other people's experiments. :)
The interference is very narrow. Here's a cheap plot of the raw data for curiousity's sake. The bins count the number of double pulse events separated by various time periods. The spike is at ~13us. The full scale represents 80us.
1192350686 32 FT32721 Tehcalcs0
Edit: oops, that's not quite the raw data, and I've been mixing up the scale. Full scale is 8us and the spike is at 1.3us. The interference is ~750kHz.
Bjørn
Sun Oct 14 2007, 03:25PM
I have a program that I use for such mysteries and it says:
750000 is a multiple of 24 by MIDI datarate (31250 Hz)
750000 is a multiple of 48 by PAL B,G,H,I,N / SECAM horizontal sync frequency (15625 Hz)
Chris Russell
Sun Oct 14 2007, 06:10PM
Chris Russell ... not Russel!
The 48th harmonic of the PAL sync frequency looks like a good candidate, but I would expect to see other harmonics in your data. Any TV sets running nearby that can be shut down?
This one is a bit further off the mark, but you might want to consider AM broadcast interference as well. I'm not sure where your university is, but it may be in close proximity to a broadcast transmitter at or near that frequency.
Bored Chemist
Mon Oct 15 2007, 06:00AM
Can you tune a radio to it? Any modulation might help to ID the source and you can walk about + see where the signal's strong.
Hazmatt_(The Underdog)
Mon Oct 15 2007, 09:37PM
What's the Frequency of your college AM Radio Station?
