  • Guests: 36
OiD (38)
jolty (50)
Baran (29)
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Crystal oscillators
Marko
Fri Oct 12 2007, 12:40PM Print
Hi all,
I just came into a need of a stable squarewave source in low Mhz.
Crystal oscillators are not something I'm familiar with and I would really want to know more about how they work.
I wanted to use a discrete quartz. First thing I lashed up was a crystal over a single 74hc14 gate - it worked, but stability was poor, sometimes it wouldn't oscillate before I touched it by a finger.
Used 4Mhz crystal, at most, 12Mhz worked.
I couldn't get the 32.768kHz watch crystal to work. Only briefly and noisy while I was actually touching the input - it would probably require careful biasing like 74LS04 gates did -see next..
I tried several different caps between crystal and ground (10-100pF) and some pullup resistors, none seemed to help much.
I was very unhappy with the output waveform from the IC too.
Output has to high impednce, rings a lot even with scope probe capacitance and duty cycle seems impossible to keep even.
My biggest problem is that I hardly understand how these things work at all.
I tried constructing an oscillator of 74LS04 gates which I hoped for to be faster, but I just couldn't get it to oscillate.
After half an hour fiddling with potentiometers and nearly exactly copying this circuit Link2 I made it to work, and was stable, but waveform didn't look any better than HC14 version.
I know that it's bad to use logic circuits in linear mode like this, but I rather wouldn't use any special components here.
I tried to construct discrete pierce oscillators which output sinewave but hardly any worked unless it was a directly copied circuit with exact crystal.
What I want is to build an oscillator with discrete crystal with available components that will output at least a decent square wave of few Mhz into scope probe load.
I noticed micro controllers use comparators at their Xtal input - but I don't think I have any that fast.
The crystal appears to be usable both in series and parallel resonant modes. Most oscillators are parallel, though.
I would greatly appreciate all tips regarding this, and some designs I could use.
chip output; my scope could be too slow for this, but still I don't think I'm having duty cycle increased to 60% for that reason. I'm using two buffer gates here.
1192192846 89 FT0 P1010003
probe in this pic is not in it's place
1192192846 89 FT0 P1010001
ShawnLG
Fri Oct 12 2007, 01:10PM
I have read somewhere that a 74AC04 is recommended when using it as a crystal oscillator. Also put a 1M ohm resistor in parallel with the crystal to start the oscillation on turn on. Sometimes you would need to use a small pulldown capacitor around 22pf to 33pf on the input an output inverting pins to help stop higher frequency operation. One thing about this type oscillator is that it will not be 50-50 square wave. You will need to double your target frequency and divide it through a D-flipflop to get a 50-50 square wave.
Tom540
Fri Oct 12 2007, 03:09PM
Tom540 Banned on 3/17/2009.
I've used crystal oscillators with 74HC14's before. Put the crystal in parallel with the inverter and 1M ohm resistor across the inverter just like Shawn said. I used 15Pf caps on mine but it depends on the crystal. Thats all you need. It works for the 32.768 crystals too which I used for IR detectors on robots. Since I'm bored at work I'm going to draw it for you.
1192201728 487 FT32650 Osc
Avi
Fri Oct 12 2007, 04:24PM
If you connect the output to the input of another gate it will possibly have a better waveform and also will not 'load it down' when you try to use the signal.
Fri Oct 12 2007, 07:03PM
Marko, this Link2 is quite good
Marko
Fri Oct 12 2007, 07:30PM
Tom, that's *exactly* what I did adn I can't get the watch crystal to work. I used 12pf caps.
It oscillates only when I'm holding it with hand and waveform is noisy - scope can't trigger to it, and on some spurious frequencies 500khz and up.
I'l twiddle some more with it this evening.
Sulaiman: I actually have the article from very long ago.
As I figured out, the capacitors ''tune'' the crystal which behaves like a sort of inductor?
What caps do you guys use for 32.768kHz crystal?
Also, I do always use buffer gates, as I already stated. The shown waveform is actually inverted oscillator output.
Bjørn
Fri Oct 12 2007, 08:10PM
Crystals are quite sensitive so if you don't get one to work properly there is a chance of it being damaged.
This page has good iformation about 32768 Hz oscillators: Link2
Tom540
Fri Oct 12 2007, 08:20PM
Hmm, it has been a long time since I've tried it but I have an old board sitting on top of my bench as we speak with this circuit In it. I'll fire it up tonight and double check the circuit. It uses a 40KHz crystal on it.
You do need the output going through another inverter. I got the 15pF caps value form the crystals datasheet.
By the way I remember someone saying that some crystals are meant to operate in harmonic mode. They might be squirrelly or something.
Amateur-Scientist
Fri Oct 12 2007, 11:18PM
Amateur-Scientist Registered Member #1015 Joined: Fri Sept 21 2007, 06:43PM
Have you looked at the SG-8002 from Epson? I've used these in the past and they work great. Digikey has them for about $5. You just tell them the frequency you want in the notes when you order.
Marko
Sun Oct 14 2007, 09:37PM
I always use at least one additional buffer gate; but still duty cycle is always uneven and waveform is ringy. Flip flop definitely helped there a lot!
BTW, I had no clue how accurate cap values need to be for those watch crystals. Thanks guys for now ^
