  • Guests: 89
12/25 Kolas (18)
12/26 buxtronix (50)
Super Capacitors
Overclocked
Thu Oct 11 2007, 11:23PM Print
Overclocked Registered Member #1056 Joined: Thu Oct 11 2007, 11:15PM
How come no one has Used Super Caps In a Coil Gun Yet? By Super Caps I mean the 5.5V 1Farad Kind, like these:
I was going to buy a couple for a portable one I want to make, but figured Id get some opinions first.
If that doesnt work, I do have a backup plan, in which I have 50 1,000uF Caps rated at 50V Each. (which equates out to 62.5 J Total). If I got 10 of those 1 Farad caps, and ran them at 5V Each, that would equate to 125J And In about half the size of the caps I have.
Fri Oct 12 2007, 12:02AM
Those capacitors are designed for memory backup and low current power supply filtering. They have extremely high ESR (Equivalent Series Resistance), and cannot source more than a couple amps. They also like to self destruct when run into a dead short, and because of their low tolerance for abuse, would almost certainly be destroyed in the first few shots by the inductive 'kick back' generated by the coil.
Car audio capacitors are better suited (built for rapid discharge and recharge) however they have a very low energy density, and are quite expensive. General purpose 'computer grade' electrolytics, and more so inverter grade 'lytics are far better suited for such a purpose, and are much more economical and practical.
Your 1,000uF 50v caps could work, but I'd recommend not putting them all in series. You'd probably get a higher peak discharge current with a combination of series and parallel (referred to as a cube configuration), as this would help reduce the ESR of the bank overall. Probably something like 5 in series, then ten banks in parallel.
Alternatively, I've got several dozen 250V 680uF caps here gathering dust. They're about 21 Joules a piece. If you're interested, PM me with your mailing address and I'd be happy to throw 10 in a box and send them your way.
Dave
Overclocked
Fri Oct 12 2007, 02:03AM
= Dave Marshall wrote ...
Posted: Thu Oct 11 2007, 08:02PM
Dave
Wow thanks a lot! Luckly I can Generate Somewhat high voltage using a 555 Timer. This is how I was getting 50V from 5V. I'll have to make a bigger inductor for larger voltages. I was going to put the whole bunch in parallel, since I figured there would be lower ESR.
I used the circuit from this site Link2 and just put in my own values. The Inductor I used was actually a Test Coil, made of 17AWG Wire. Total Inductance was 7.22uH (estimated). So 250V Shouldnt be that hard to get to. How big are The caps? Are they small or Jumbo Sized?
Playing with Numbers, It seems I get the same Energy No Matter which Combo I use (more or less).
Myke
Fri Oct 12 2007, 02:10AM
With out changing the number of caps and changing the series and parallel banks you will always get the same total amount of energy stored.
rupidust
Fri Oct 12 2007, 02:47AM
rupidust Banned
Registered Member #110 Joined: Fri Feb 10 2006, 12:23AM
How come no one has effectively used...? is a better question. People have neither not known about nor decided to not attempt. People simply have come to realize after making attempts that its a lost cause.
The super caps do not meet the current requirements. Just as car batteries are not AA cells, coil guns do not use 5.5v 1 Farad super caps. The max discharge current is no where near high enough for high current applications.
How come I need to tell you this?
Overclocked
Fri Oct 12 2007, 03:20AM
= rupidust wrote ...
Truthfully I didnt know this. I figured all caps are equal in charge and discharge despite their capacitance rating.
Hazmatt_(The Underdog)
Fri Oct 12 2007, 03:39AM
Read the specs. of your caps carefully, they are designed to source a few up to tens of milliamps, not amps.
They are also a Sulphuric Acid electrolyte cell, so if it ruptures, be mindful of what you're dealing with.
Fri Oct 12 2007, 04:01AM
In his defense, I will say that specs for surplus caps in general, but particularly super caps as seen on most sites like Alltronics and Electronics Goldmine are damn hard to come buy. They provide few details. A model number if you're lucky, and maybe even a manufacturer, but its a crap shoot.
I've attempted to find info on those caps for other projects, and was thoroughly frustrated.
Dave
Overclocked
Fri Oct 12 2007, 04:24AM
There are Specialty Caps That are used For high Energy Apps (such as pulse power) But a .5F Cap goes for about 17 bucks!!! Totally not Worth it...For that much I can probably get a couple 400V Caps from One of the Surplus Sites.
Is there an Upper Limit For The size of the Coil? Im going for Single Coil since it would be easy for my first time Around. I actually un-wnded a MOT and got the wire from there. One hell of a PIA! But the wire is in good condition, and the Microwave was working. There was a bit more than 1Lb Of wire.
Bjørn
Fri Oct 12 2007, 05:24AM
Have a look in the wiki and the archives, almost all sensible questions about simple coil guns are answered there in one way or another.
Making a coil gun is simple, making an optimal coil gun is difficult. The general consensus is that you should just make one and experiment with different configurations of capacitors and coils. That way you will learn efficiently and discover many things you would never have thought about.
You should also put some effort into measuring the projectile speed accurately so you can judge your progress.
