  • Guests: 45
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Induction heater match coil
PAVALOS
Thu Oct 04 2007, 10:52AM Print
PAVALOS Registered Member #1042 Joined: Thu Oct 04 2007, 08:06AM
Hi all
Can anyone tell me any theory or how to convert this work coil of 80 turns ~80uh to a new work coil lets say for example a six turn cooper tube coil? I know that the lclr sollution is the best but what is the value of matching coil and matching capacitor? This circuit works on ~300V at 50KHz
2
Thu Oct 04 2007, 06:35PM
The capacitor is sized to resonate with the work coil. So say you used 8 turns and got a 1.5µH work coil, the capacitor should be 6µF to resonate at 50 kHz. Assuming you want to run it in LCLR resonant mode, you'll need a matching inductor too, which I don't know how you calculate the size of either. It seems to be a matter of trail and error. From what I've gathered a larger inductor will limit power, so start with 150µH and lower the inductance until you reach the desired power level. A gapped ferrite or air core was ideal IIRC.
Personally I had little success with the LCLR topology, my matching inductor would get hot instead of the work piece. So I just used a matching transformer and series resonance, it worked fine. Impedance matching for induction heaters had been up before, just check this thread. Link2
PAVALOS
Fri Oct 05 2007, 10:02AM
Thank you i will try it and post the results soon
