  • Guests: 54
Coil cannon HV
spacifique1
Sun Sept 30 2007, 06:38AM Print
spacifique1 Registered Member #1035 Joined: Sat Sept 29 2007, 01:24PM
Hi. I stripped a microwave oven and have the transformer and capacitor sitting spare. I want to build a low-tech coil gun(cannon?!) using a car ignition distributor (four or six cylinder) to handle the switching part. I need some info on how to design the best coils for this application (inductance, turns, wire diameter). It will be running about 1KW in four or six coils if all is well.
Sun Sept 30 2007, 12:42PM
I'm no coilgun expert, but I think a good start would be to toss all of those parts out and start again with different ones, such as electrolytic capacitors and SCRs.
Shaun
Mon Oct 08 2007, 04:26PM
You need a lower voltage, MUCH higher capacitance, and lots more overall stored energy.
