  • Guests: 39
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Strobe light with Tl494 or AVR microcontroller?
cjk2
Sat Sept 22 2007, 12:54AM Print
Id like to build a strobe light (for a time fountain). I assume i will aim for something in the range of 10-20 hz output frequency. Two questions: 1. Does anyone have experience using a tl494 this "slow"? and, 2. Is there any good way to get a variable duty cycle and variable frequency signal out of a microcontroller short of using a D to A converter and a VCO?
ConKbot of Doom
Sat Sept 22 2007, 01:50AM
I'd use the cheapest micro with enough programming space for you to do what you need. I would think about a PIC12F or a smaller 16F chip if you like to work with PICs and not AVRs :p
What kind of accuracy do you need? I would imagine accuracy isnt super important, for this. (I.E. If its set for 15 hz and actually outputting 14.8 hz, not a big deal)
I would take a PIC with a Timer1 external input, feed that with a low frequency (2-5khz or so) pre-load timer1 with a value, wait for it to overflow, and load the next value in the ISR, repeat... etc
Then a few multiplexed buttons that are scanned a few times a second to control it, dutycycle up/down, period up/down. etc.
Sat Sept 22 2007, 02:07AM
If all you want is a constant repetition rate that can be preset, then a 555 would be good enough.
I suspect that for a stable time fountain it's best to synchronise the timer with the falling drops
so a photo-gate is required for best results, again a 555-based system could work.
Ultimately a microcontroller would give the most flexibility
with a crystal controlled clock no external timing/frequency reference is required.
cjk2
Sat Sept 22 2007, 03:05AM
Id like to stay away from a 555 as i want to be able to control frequency and duty cycle independently. I had planned on using an AVR if possible, i actually have some experience on them, vs. none on a PIC. I do have some of each here tho, and programmers for them. I really like the idea of a microcontroller but it still looks like there is no easy way of generating a digitally variable frequency without feeding a VCO from the micro...
Bjørn
Sat Sept 22 2007, 05:24AM
Even the cheapest micrcontroller can make a variable frequency/duty cycle adjustable to one microsecond. In your case you get an accuracy to 1 in 50 000. A few hundred times more than you really need, unless your water is a special stable type.
Low frequencies are easy with microcontrollers.
thedatastream
Mon Sept 24 2007, 08:33PM
An ATtiny13 would be more than adequate for this task and that is one of the most basic AVR micros that Atmel make.
cjk2
Thu Sept 27 2007, 02:37AM
Thanks for the help guys, I'm using a Tiny2313 as i have some of these on hand. Its working great. When my fountain is done (currently waiting on the pump to arrive) ill be sure to post in the project section and share my design.
