  • Guests: 41
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
PCB layout to Steve's PLL driver
Fri Sept 21 2007, 11:11AM Print
Hello, anyone here got a PCB layout for Steve Connor's PLL driver ? http://www.scopeboy.com/tesla/dwsstc/wk2.html
If not, good and easy way to make PCB layout myself ?
Avalanche
Fri Sept 21 2007, 04:22PM
Here you go (see attached zip) There's a PDF of the board - print it at 100% and expose toner side to board (I think, double check)
Image shows the component placement. It's not quite as in the schematic, I put some pots in to make it a bit universal. It's not quite right.
Hope this helps!
]1190391728_103_FT31693_av_pll_pcb_layout.zip[/ file]
Fri Sept 21 2007, 10:57PM
Great, thanks. But i guess it is soon time to start make my own layouts, anyone know a easy program?
Fri Sept 21 2007, 11:18PM
Eagle: easy? not so much... Free? not so much... Still worth it? yes
I would avoid expressPCBs software like the plague. But thats just me.
Avalanche
Sat Sept 22 2007, 12:02PM
Diptrace do a freeware edition and that's what I've been using. Eagle is bit weird at first, everything behaves differently to how you would expect. Not sure if I'm going to bother with that one now. One of the best packages IMO (although not free) is Easy PC which I now use almost everyday.
