  • Guests: 41
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Driving mosfet gates in a royer negative.
Marko
Wed Sept 19 2007, 04:49PM Print
This was the basic idea:
1189627693 89 FT30472 Isolated Pulldown Sources
And the question is simple, why doesn't it work?
I used 1,5V batteries with decoupling caps to provide isolated sources. Feedback diodes were two series 1N4148's which seemed to drop down about 2V total in this case.
When I used one battery per leg, the minimal gate voltage dropped to about 1V;
When I put the next one in series, the voltage went down to almost perfect zero except for some ringing. At that point I thought it's an epic success, but soon got disappointed.
When I seriesed another battery hoping for more negative voltage, the circuit didn't want to oscillate.
Same was with 9V batteries or any other source.
And I'm still banging head what's happening and what should I do. If I can get this to work it would make best possible feedback I know.
Can anyone give me a clue what's logically wrong with the arrangement?
Maybe I should use the source in series with the gate, and higher drive voltage?
Or put it behind diodes?
Help.
Wed Sept 19 2007, 06:31PM
Could you just be having problems due to the high ESR of a battery? Perhaps a little cap across the battery would solve it?
Marko
Wed Sept 19 2007, 07:54PM
I already said, I decoupled the batteries with caps, 100nF ceramics and 470uF lytics respectively. But I simply lose oscillation when I try to drive it just a fraction of volt into negative.
I bet somebody with good whack for logic can solve this easily.. ^ ^
Wed Sept 19 2007, 09:01PM
I think it's because both MOSFETs need to be on at once to get the circuit started. It really doesn't matter if both devices are on at once. The ZVS is a current-fed inverter, so it can't be hurt by shoot-through. Bad things only happen if both devices turn *off* at once causing the DC link choke to kick back, which is bad in the same way as shorting out the DC link with shoot-through on a voltage-fed inverter. If you want to know more, read up on the principle of duality.
Marko
Wed Sept 19 2007, 10:53PM
Hi all, steve,
BTW I PM'ed you again, couldn't resist, I'm sorry for being cumbersome angry
I completely agree with you, although off-through condition is something yet to be seen, since mosfet delays always take care of that. smile
I did although see some weird artifacts in voltage waveform on the inductor, but nothing over like 10% of main amplitude.
Now, I have managed to get the negative drives working! smile
I use four small IRFU410 mosfets (2 in paralell) since they have much smaller delays, are free from CFL's and ideal for study.
The thing decided to work when I put the batteries 'before' main diodes and with reverse Schottky diode in parallel.
Batteries got quite loaded, but pulled the gate down to -5V.
The circuit did not want to start until I applied main power, and even then sometimes it would just short the supply. (Small mosfets handle the shorting nicely due to their high resistance). Definitely not something reliable yet!
From theoretical side, mosfets should turn on into metastable state same as without negative supplies, at least as I think. I don't see anything that may be causing trouble.
I really owe a hug to anyone who can resolve what is exactly happening here! lol.
If you ask why is this all about, I simply want faster and more efficient gate drive. I don't think it can be too fast in tis kind of circuit, can it?
My last circuit used a heavy slow 600V diode and large pullup resistors. Due to voltage drop of ~1.5V on the diode I was unable to drive any kind of active pullup, nor UCC's nor small mosfets with <1V treshold voltage.
With negative drive I'l be able to use a series string of 1N4148's since forward drop isn't very important anymore; very fast and cheap.
Large passive pullups were slow, hot, and caused mosfets to spend large part of half cycle in linear region, which in turn made the mosfets very hot.
Shown waveforms are slowish too despite only 400pf of capacitance, I plan to get them into perfection...
I need sleep badly now...
1190242391 89 FT31616 Negative 1
