  • Guests: 45
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Capacitive ballast
Tue Sept 18 2007, 06:11PM Print
Is it ok to capacitively ballast [current limit] a transformer (on the primary side) if I stay away from resonance?
Marko
Wed Sept 19 2007, 06:16PM
I think it has been done, but I can't find any good enough links.
Cap should work as long as it is fairly higher-than resonant; in that case you'l have capacitive reactance into mains.
What transformer are you using it for? Capacitive ballast will have poor cost efficiency over inductive ballast for any higher power levels.
