  • Guests: 32
Hanzie (31)
badger (52)
h3X (40)
01/12 RoV IW3IPD (63)
Electrostatic dust kicker?
Air2air
Tue Sept 18 2007, 03:17AM Print
Air2air Registered Member #1010 Joined: Mon Sept 17 2007, 11:45PM
What a great forum.
I'm prototyping a hand-held 110V tool. It has a filter screen where the usual dust and debris collects. Is it possible to create a static discharge that would "kick" off the dust particles? Can't use vacuum or any other method.
- Is it possible to cram the neccessary components into a small enough size for a hand-held power tool?
- Any safety issues to be concerned about?
Thanking you in advance!
Tue Sept 18 2007, 06:23AM
I doubt that a static charge could 'kick' dust off
but a secondary grid could maybe attract dust then 'drop' it?
Air2air
Tue Sept 18 2007, 03:59PM
Ah thanks Sulaiman. What are your thoughts on the size of the electrical system; how small you could make it, and the best design for this application?
We're talking about a half a teaspoonful of dust, removed every several seconds or so. Could the secondary grid stand off from the primary about, say, half an inch?
Tue Sept 18 2007, 04:47PM
Sorry, beyond my experience level.
Coyote Wilde
Tue Sept 18 2007, 04:51PM
Coyote Wilde Registered Member #175 Joined: Tue Feb 14 2006, 09:32PM
That would depend on the mass/composition of the dust, the relative humidity and power available.
Safety isn't that big of an issue-- you'll still need kV for the E-field, but the overall power level probably won't get anywhere lethal; just use common sense.
But if this tool is being sold to Joe Public, I'd expect this part of it to be vetoed by the insurance people.
Air2air
Tue Sept 18 2007, 05:46PM
Thanks to both of you.
Coyote, the dust would be your normal sanding dust - it's on a sander. So a power source is always available. If you were me, where would be the next place to get some components for prototyping? You can tell I am a newbie in this area.
thedatastream
Tue Sept 18 2007, 07:40PM
My Canon D400 has a piezoelectric element attached to the CCD which is supposed to shake the dust off. Don't know if it works or not but you could prototype and try something similar
